Date/Time: Sat, 27 Apr 2024 15:16:18 +0000
Study summary window
View Count: 791
[2017-11-26 05:33:55] |
nicktrader - Posts: 665 |
After each start the Study summary window opens, although no selection. Is there a way to switch that off. |
Study Summary Window.png / V - Attached On 2017-11-26 05:32:35 UTC - Size: 5.04 KB - 266 views |
[2017-11-26 05:42:37] |
This will be fixed with a new release later today.
[2017-11-27 04:03:49] |
I am running the latest release (1652) but same old story. I use SC on two different PCs. The second does not cause this problem because I did not open the window previously (File / Open Study ...) |
[2017-11-27 04:20:13] |
We do not see any problem with this. Close the Study Summary window and save the Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
