Date/Time: Sat, 04 May 2024 21:52:41 +0000
Roll over procedure
View Count: 1338
[2013-09-14 04:50:20] |
Willson - Posts: 176 |
Table of contents "symbols" links to Supported services. Cant find procedures to roll over chart contract names if there is such a procedure. Any guidance appreciated. I have many charts using HMZ contract nomenclature on IQ feed. Hoping to convert them to new contract without manually converting each chart. Regards |
[2013-09-16 02:42:40] |
Here are the instructions you need: https://www.sierrachart.com/index.php?l=doc/doc_ChangingFuturesContract.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
