Date/Time: Sat, 04 May 2024 17:59:56 +0000
Inaccessible menus
View Count: 664
[2017-11-25 12:33:12] |
DabbaDo - Posts: 146 |
v1649 and v1651, at least. If on General Settings + General 4 I check "Bring Detached Windows to Top on Main Window Focus" then on a detached window I can use the menus, but on the main chart I can't. E.g. clicking File or Edit or Chart does nothing. Cheers, Dale |
[2017-11-25 21:43:23] |
This will be resolved in the next release. The problem is the focus keeps switching back to one of the detached charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-25 21:43:38
