Date/Time: Sat, 04 May 2024 17:52:03 +0000
Rollover methong for Buxl
View Count: 886
[2017-11-25 09:56:36] |
Usermb - Posts: 126 |
SC Data Symbol: GX Currently Buxl uses rollover Method6. IMHO it should use Method8 just like Bund (GG). The Buxl is already rolled, but there basically no trades in H18 compared to Z17. |
[2017-11-25 13:27:01] |
SP doesn't have a rollover configured right now. IMHO this should be similar to ES: Method3(8, 3)
[2017-11-26 21:38:57] |
Both of these are resolved. Symbol Settings will be updated in about 10 minutes.
[2017-11-27 23:27:07] |
RTY also seems to have this problem, should probably be Method3(8, 3) as well
[2017-11-28 04:17:53] |
We apologize for this. This was an oversight. This rollover rule has now been added everywhere that it was missed for RTY.
