Date/Time: Sun, 28 Apr 2024 09:31:04 +0000
Automated trading system
View Count: 2065
[2017-11-24 16:04:10] |
User95457 - Posts: 19 |
I would like to have orders executed by an automated trading system. It is very simple, an entry order when the DM+ crosses the DM- (and viceversa) of the DMI indicator; I have completely no experience in C++ codes or programming, is there a ready to use template to attach to my DOM based/using that Indicator?
[2017-11-24 20:44:42] |
Yes, we have a trading system you can use to accomplish this. Did you want to set Target and Stop orders as well? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-24 21:26:13] |
Yes, I did. I'd like to set OCO orders, Buy stop sell stop. In particular take profit should be a limit order while stop should trail to breakeven. Also, in case the market doesn't reach the TP and there's a reverse cross of the DM+/DM- lines, the trading system must close the previous position at the same entry level of the new order. How can I get it?
Date Time Of Last Edit: 2017-11-24 21:26:46
[2017-11-27 02:01:25] |
Yes all of this will be supported. We are working on a trading study to do this. It will be named: Trading System - Study Subgraph Crossover It should be out tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-27 02:01:36
[2017-12-01 19:42:09] |
Is this trading system now available? Where can I find it?
[2017-12-01 19:44:39] |
Yes it is but it is undocumented. It is in the current version of Sierra Chart. It is a study named: Trading System - Study Subgraph Crossover Update to the current version following these instructions: Software Download: Fast Update It supports Attached Orders which can be defined on the Trade Window of the chart. Refer to: Attached Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-09 04:07:35] |
user8888 - Posts: 159 |
Is the source code of this study available? if so, where?
[2017-12-09 11:55:47] |
Yes it is. It is in: /ACS_Source/TradingSystem.cpp. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-23 13:13:38] |
I launched the trading system but it only works with market orders to enter the market. How can I set attached orders as default? I would like the trading system to work with OCO orders set by me with pre-defined target and stop loss levels. Thank you for your support. Date Time Of Last Edit: 2018-02-23 13:15:03
[2018-02-23 18:14:14] |
To use Attached Orders , they need to be configured and enabled on the Trade Window for the chart the trading system is applied to. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html#AttachedOrderWindowInterface Also here is documentation for the study: Trading System - Study Subgraph Crossover Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
