Date/Time: Tue, 14 May 2024 15:51:36 +0000
Add StopLoss to an open trade
View Count: 1914
[2017-11-24 11:16:01] |
User215298 - Posts: 20 |
Hello team hope you are well. Very basic question - I have been reading through the Attach Order feature and learned how to do bracket orders etc, now: let´s say I have an open buy order, how can I add a simple stop loss to it? I go into the trade window for chart, set the stop loss but then.. what do I have to press to make it work? I have read through the "Changing Attached Orders Configuration After Parent Order Has Filled" but still can´t figure out! thanks! Thanks |
[2017-11-24 11:25:32] |
You just simply submit the Stop order as a single independent Stop order. You do not need to use Attached Orders for this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-24 11:25:47
[2017-11-24 11:43:12] |
thank you for your quick reply! apologise for my dumbness.. what is the button to "submit" the order? do I have to send necessarily an opposite sell stop? I am asking because I am limited by my broker by the number of orders I can open at a given time. Thank you!! |
[2017-11-24 11:48:55] |
Easiest thing to do is just to follow the instructions here to submit a stop order: Chart Trading and the Chart DOM: Entering Orders From the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-24 11:50:34] |
Or once you have set the controls to submit the stop order on the Trade Window then simply use the "Sell" button at the bottom of the Trade Window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-24 11:50:52
[2017-11-24 12:06:09] |
thank you!
