Date/Time: Sun, 28 Apr 2024 23:44:06 +0000
Strange Error Message
View Count: 961
[2017-11-24 05:32:56] |
User78442 - Posts: 260 |
I had this message appear and I had to restart - Please advise reason/remedy
SC Error Message.jpg / V - Attached On 2017-11-24 05:32:49 UTC - Size: 1.34 MB - 284 views |
[2017-11-24 06:06:06] |
There are two things that we need from you to determine the problem. If there is a particular Chartbook file this occurs with, we need you to attach it following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Also attach the Sierra3.CFG file in the main Sierra Chart folder. Both of these can be privately attached. Also did this happen after opening a particular Chartbook ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-24 06:07:52
[2017-11-26 16:27:03] |
This occurred just now with a DXY Chartbook. Enclosed CHT & CFG Files
Private File Private File |
[2017-11-26 22:16:12] |
We were unable to reproduce that error message you are getting using this Chartbook and global configuration file. It might be Windows 10 specific. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-27 08:46:56] |
I rolled back the last MSW 10 update...I'll see if this works
[2017-11-27 18:53:54] |
OK when you have the problem do you notice any obvious issues with Sierra Chart? If you still have a problem, one thing you can try but we do not know if it would make a difference, is to reset Sierra Chart to a default state. Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails39.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-27 18:54:58
[2017-11-28 02:45:12] |
FYI I rolled back to MS Windows 10 Ver.1703, OS Build 15063.726 I have not had the issues of disappearing windows or the fatal error message now in appprox 1 day. I run 5 monitors on Nvidia cards. I am keen to keep up to date with Windows updates .. I appreciate that keeping up with MS updates in SC is hard, but do you have a process/documentation that shows what SC version is compatible with what MS Update? For the moment I have disabled updates and wait for a longer term solution _ Switching OS is not an option.
[2017-11-28 02:49:46] |
. I appreciate that keeping up with MS updates in SC is hard, but do you have a process/documentation that shows what SC version is compatible with what MS Update? In general, there is no program for the Windows operating system that needs to be concerned with Microsoft updates. The last time we ever did anything in response to a Windows update was when Windows Vista came out and there were only a couple of minor changes needed.but do you have a process/documentation that shows what SC version is compatible with what MS Update? No, there is no such thing. And if Windows was so unstable and unpredictable to require something like this there is no point in anyone using it.
