Date/Time: Wed, 15 May 2024 20:59:10 +0000
ReplaY; Accurate Trading System Back Mode has quit working (at least for me)
View Count: 835
[2017-11-23 16:29:20] |
GiantAvocado - Posts: 67 |
V 1644/1649 It started on Wed 11/22; I have been doing many backtests for system analysis (automated spreadsheet trading) then all of a sudden when I hit "Play" the chart reloads and that is it, no more action. The replay panel sits there back to "Play" button focused; in the log is says; [replay 60X 'any product' reloading chart; date;] This testing is on automated spreadsheets for trading that have until now successfully replayed; Tested this issue on two different computers with different trading systems, with no success; I have tried almost all speeds & different variations with no success; even 'standard replay' has the same reaction; I even loaded the example chart book with the USD/EUR & .scss files & when I run it get the same result; I downloaded today the latest version of SC & same response; I am not sure if I did something to cause this or not & I can't figure out why this has happened. Please point me in the direction to fix this, thx... |
[2017-11-23 19:31:59] |
Additional notes: I reverted back to version 1629 on one machine and the replay works fine; the other machine, version 1644 will do replay only as long as you select "start date & time" & assign a date & time. |
[2017-11-23 19:39:28] |
Make sure you follow through the step-by-step instructions here: Replaying Charts: Basic Chart Replay Instructions The other possibility which is unlikely, is that there is a problem with the timestamps of data in the chart. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-23 19:40:43
