Date/Time: Sun, 28 Apr 2024 09:30:13 +0000
Strange Data After close of Pit Session
View Count: 823
[2017-11-21 11:46:46] |
User164231 - Posts: 278 |
Hi Could you explain the sudden long upper wick after close of session? I tried this Question about ETF to no avail. Could you explain why this happen and how to prevent and correct it? Thanks. |
[2017-11-21 17:34:07] |
How do you know that the data is incorrect? We do see that as well but the high value is based upon the data received from the data feed.
[2017-11-22 08:10:40] |
Hi, strangely the Data feed does not have that anomaly if viewed from the charting platform. Please investigate.
[2017-11-22 08:32:01] |
All indications are is that data is correct. You cannot put any reliance on what Trader Workstation shows since their data is not always complete since they do not provide a complete tick by tick data feed.
[2017-11-26 02:17:02] |
My bad, you are right.
