Date/Time: Mon, 29 Apr 2024 01:26:19 +0000
Custom Bar Period Not Changing
View Count: 643
[2017-11-20 01:06:05] |
User942178 - Posts: 25 |
I have had my custom bar period set at 5 minutes and 10 minutes and have been able to change back and forth on any open chart. As of Friday, I can no longer change from a 5 minute to a 10 minute chart using my custom bar period setting. I have taken the settings off the tool bar and reset them but they still will not let me change from 5 minute to 10 minute charts. Can you help me correct the issue? Thank you. Maria McBride |
[2017-11-20 19:34:51] |
Is the chart you are trying to change the time period of, a detached chart? For an understanding of this, refer to: Detaching and Attaching Chart Windows If so, make sure that chart has a Control Bar displayed on it: Control Bar: Window >> Control Bars >> Control Bar [1-8] And use that Control Bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-20 19:35:45
