Date/Time: Sat, 04 May 2024 07:22:49 +0000
CQG FIX login issue after reformating computer
View Count: 1073
[2017-11-20 00:26:03] |
toews&kane - Posts: 209 |
Hi, I am having a connection rejected issue, is this related to reinstalling of the application? CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-11-19 18:48:44 CQG FIX socket (246) | Creating socket. Using TLS 1.2. | 2017-11-19 18:48:44 CQG FIX socket (246) | Connecting to IP: 208.48.16.214. | 2017-11-19 18:48:44 CQG FIX: Sending the Logon message. | 2017-11-19 18:48:44 CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2017-11-19 18:48:44 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2017-11-19 18:48:44 CQG FIX socket (246) | Adding bytes from final send buffer from buffered socket: 112 | 2017-11-19 18:48:44 CQG FIX socket (246) | Initiating close of socket by core. | 2017-11-19 18:48:44 CQG FIX: Disconnected. | 2017-11-19 18:48:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-19 18:48:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-19 18:48:44 CQG FIX socket (246) | Sending bytes from final send buffer: 112 | 2017-11-19 18:48:44 CQG FIX socket (246) | Write in progress. Shutdown being delayed. | 2017-11-19 18:48:44 CQG FIX Trading | Disconnected. | 2017-11-19 18:48:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-19 18:48:44 CQG FIX socket (246) | Write has completed. Shutdown being performed. | 2017-11-19 18:48:44 CQG FIX socket (246) | Shutdown started. Waiting for graceful close. | 2017-11-19 18:48:44 CQG FIX socket (246) | Socket gracefully closed by remote side. | 2017-11-19 18:48:45 CQG FIX socket (246) | Closed. | 2017-11-19 18:48:45 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-11-19 18:48:47 CQG FIX socket (247) | Creating socket. Using TLS 1.2. | 2017-11-19 18:48:47 CQG FIX socket (247) | Connecting to IP: 208.48.16.214. | 2017-11-19 18:48:47 CQG FIX: Sending the Logon message. | 2017-11-19 18:48:48 CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2017-11-19 18:48:48 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2017-11-19 18:48:48 CQG FIX socket (247) | Adding bytes from final send buffer from buffered socket: 112 | 2017-11-19 18:48:48 CQG FIX socket (247) | Initiating close of socket by core. | 2017-11-19 18:48:48 CQG FIX: Disconnected. | 2017-11-19 18:48:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-19 18:48:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-19 18:48:48 CQG FIX socket (247) | Sending bytes from final send buffer: 112 | 2017-11-19 18:48:48 CQG FIX socket (247) | Write in progress. Shutdown being delayed. | 2017-11-19 18:48:48 CQG FIX Trading | Disconnected. | 2017-11-19 18:48:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-19 18:48:48 CQG FIX socket (247) | Write has completed. Shutdown being performed. | 2017-11-19 18:48:48 CQG FIX socket (247) | Shutdown started. Waiting for graceful close. | 2017-11-19 18:48:48 CQG FIX socket (247) | Socket gracefully closed by remote side. | 2017-11-19 18:48:48 CQG FIX socket (247) | Closed. | 2017-11-19 18:48:48 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-11-19 18:48:51 CQG FIX socket (248) | Creating socket. Using TLS 1.2. | 2017-11-19 18:48:51 CQG FIX socket (248) | Connecting to IP: 208.48.16.214. | 2017-11-19 18:48:51 CQG FIX: Sending the Logon message. | 2017-11-19 18:48:51 CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2017-11-19 18:48:51 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2017-11-19 18:48:51 CQG FIX socket (248) | Initiating close of socket by core. | 2017-11-19 18:48:51 CQG FIX: Disconnected. | 2017-11-19 18:48:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-19 18:48:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-19 18:48:51 CQG FIX socket (248) | Write in progress. Shutdown being delayed. | 2017-11-19 18:48:51 CQG FIX Trading | Disconnected. | 2017-11-19 18:48:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-19 18:48:52 CQG FIX socket (248) | Write has completed. Shutdown being performed. | 2017-11-19 18:48:52 CQG FIX socket (248) | Shutdown started. Waiting for graceful close. | 2017-11-19 18:48:52 CQG FIX socket (248) | Socket gracefully closed by remote side. | 2017-11-19 18:48:52 CQG FIX socket (248) | Closed. | 2017-11-19 18:48:52 File >> Disconnect selected. | 2017-11-19 18:48:54 CQG FIX Trading | Disconnected. | 2017-11-19 18:48:54 |
Attachment Deleted. Private File |
[2017-11-20 05:53:41] |
It is not directly related to that. This is what we see: CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2017-11-19 18:48:51 Could you contact your broker about this and check with them on your CQG username and password to make sure those are correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
