Date/Time: Sun, 05 May 2024 15:46:38 +0000
Refresh tick chart history after outage.
View Count: 1794
[2013-09-13 15:21:08] |
User30111 - Posts: 10 |
Hi am having trouble refreshing tick data after internet outage. I tried Edit>>Delete all data and download, and it did, but filled the chart with minute chart data on my 90 tick chart and then started adding 90 tick data! Any ideas Thanks http://screencast.com/t/qIq5btoasTs |
[2013-09-13 18:06:59] |
Refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-13 19:12:27] |
Thank you for the link. That sorts the problem. Brilliant. Nice w/e |
