Date/Time: Tue, 07 May 2024 11:24:24 +0000
Eror on Nonzeoro bid&ask line extension
View Count: 1291
[2017-11-17 13:21:56] |
User50187 - Posts: 19 |
I would like to advise you that there is an error in the Non zero bid&ask volume under NUmber bars study, when the Coloumn 1 with line extension is on there are lines that should not be present (attached screenshot). This is after installation of version 1640 and 1644 in the past there was a time I don't remember the sw version that it happened the same then with next release the issue was resolved. Thx Alberto |
sierra error line.png / V - Attached On 2017-11-17 13:21:06 UTC - Size: 245.77 KB - 311 views |
[2017-11-17 17:15:35] |
We do not see any obvious problems in the chart image you provided but we will test to make sure the functionality works as documented.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-17 17:15:43
[2017-11-17 17:24:09] |
Thx for aswering to me, you have the evidence in the imange, and are the two lines with the arrows, that two lines should no be present since there are a zero line values on the bars.Again I do not remember the sw version some months ago when this function was released i saw the same issue but you then fix it with next release. Since I downloaded 1640 and 1644 the issue come out again. Alberto Date Time Of Last Edit: 2017-11-17 17:34:59
error in non zero value.png / V - Attached On 2017-11-17 17:34:52 UTC - Size: 233.38 KB - 354 views |
[2017-11-17 23:12:14] |
John - SC Support - Posts: 31419 |
We are not able to reproduce what you are seeing. Please send us your chart book following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-20 10:04:26] |
As per your request made a full new chartbook eliminating all studies not relevant to the error and you'll find it attached and the error is still present in the same two position. The two wrong lines are still present. I'm not an expert on sw but as this issue was came out on an old release and then was fixed but next ones to came back again starting with 1640 it's higly probable that some register modification due to implementation of new features created a conflict with the specific study recreating the issue once again. Thx Date Time Of Last Edit: 2017-11-20 10:05:54
Chartbook11.cht - Attached On 2017-11-20 10:03:46 UTC - Size: 32.11 KB - 350 views |
[2017-11-20 10:38:38] |
NumbersBars - Posts: 141 |
@User50187 Just out of curiosity, I did a quick test of your chartbook. The extension lines look ok to me. I loaded with CL and Bund, both look fine. Attached is the Bund chart. Let's see if SC support can reproduce the problem you were seeing. |
extension.png / V - Attached On 2017-11-20 10:37:51 UTC - Size: 76.4 KB - 317 views |
[2017-11-20 12:52:23] |
@FTM crew thx for testing well as I wrote it's probably something that happened into the registry with the istallation of the 1640 and 1644 version that i'm running wright now, so it's possible that could be ok for somebody else and not for me but since months it was all ok. Let's see if sierra team can reproduce it. |
[2017-11-20 15:11:52] |
We are still unable to reproduce the problem, even with your chartbook. The attached image shows what we see with your chartbook. http://www.sierrachart.com/image.php?Image=1511190527643.png For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-20 19:47:25] |
I trust You but as I show you on my picture on my sierra account that's what I saw. I will try to move to the next release 1647 and see if the issue disappear or not. No any other idea how to solve it. I take the oppotunity to ask You if you have in plan to insert an indicator to have a line creation (as per non zero line),but to indicate, in the number bars study, where the market leave both ask& bid empty. Thx |
empty bi&ask.png / V - Attached On 2017-11-20 19:46:29 UTC - Size: 49.91 KB - 314 views |
[2017-11-20 20:06:42] |
as I wrote it's probably something that happened into the registry with the istallation of the 1640 and 1644 version that i'm running wright now, so This could not be the case. Sierra Chart does not use the registry and there are no global configuration variables which would affect this.
