Date/Time: Mon, 29 Apr 2024 11:59:09 +0000
% left scale problem
View Count: 1045
[2017-11-17 03:56:00] |
Kinobe - Posts: 86 |
Hi since an update, I am not able to see correctly the % scale on the left when it exceeds 100% - see picture. how can I fix this? thank you |
Pourcentage_probleme.jpg / V - Attached On 2017-11-17 03:55:18 UTC - Size: 646.52 KB - 322 views |
[2017-11-17 04:49:37] |
This will have to be looked into later by us. There is nothing you can do now.
[2017-12-13 02:56:19] |
anyway to fix it? thanks |
[2017-12-13 04:28:30] |
We have not yet gotten to this. It is on our list.
[2018-11-15 09:00:51] |
We will get started on this soon. We apologize for the delay. Did not realize so much time had gone by.
[2019-02-03 23:38:51] |
The scaling has been improved in recent versions and there is an option to control whether the study is used in the scale width or not.
