Date/Time: Tue, 07 May 2024 19:01:55 +0000
Custom color as percent of day's volume instead of percent of POC
View Count: 1151
[2017-11-15 19:10:36] |
User756444 - Posts: 3 |
New user here, and in the volume by price study I'm trying out the settings for "color code volume bars" as a percentage of POC. But what I'd find more useful is coloring them as a percentage of the day's total volume instead. Is that possible now, and if not could I make that a feature request?
[2017-11-16 10:49:27] |
We can do this, but we would require that you become a paid user for at least six months.
[2017-11-19 22:10:44] |
As we began to look into this, it seemed as though this might be something relatively easy to do but as we proceeded to do it, we realized it simply does not make any sense. The problem is the default percentages which are hardcoded would cause the coloring to just be the same for each volume bar. If the percentages were customizable, which is not something that we would support, because it is quite involved, the problem is you would have to be frequently changing the percentages based upon the volume data and changes with the Volume by Price settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-19 22:11:29
