Date/Time: Sat, 04 May 2024 14:39:11 +0000
CPU exception
View Count: 1519
[2013-09-12 20:18:53] |
user6275 - Posts: 13 |
Never seen this before, running version 1019 Warning: The Custom DLL study "sample.scsf_SampleOn" has just caused a CPU exception. | 2013-09-12 12:20:31 thanks, |
[2013-09-13 02:42:50] |
Recompile the source code file again into a new DLL . If you still see the problem, this is something you will need to debug. Refer to the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_DebuggingDLLs.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
