Date/Time: Mon, 29 Apr 2024 23:29:45 +0000
Bitcoin Data - Adding Bitfinex Symbols
View Count: 1830
[2017-11-10 19:54:48] |
User959243 - Posts: 2 |
Hello, The Bitfinex Data Feed is not complete and has lots of old symbols that aren't even used anymore. Also it seems the API was updated and the current Implementation is "lagging out". Current Pairs can be looked up here: https://api.bitfinex.com/v1/symbols Is it possible to have a look at that data feed? |
[2017-11-11 22:46:17] |
This will come in time, hopefully within two months.
[2017-11-25 19:34:43] |
rhovega - Posts: 279 |
+1 to this. Even if only data available (no trading), charting on SC is still useful. Of the main Bitfinex coins/symbols, the following are either missing or not working: BCHUSD, XRPUSD, NEOUSD, IOTUSD, ZECUSD. |
[2018-04-10 14:15:36] |
Hello, Thank you so much for the update! After testing it out fully, i'm fully pleased with the current update/upgrade even with the integration of Bitmex. It's a pleasure using Sierra Chart. Only one outstanding issue remains: 50 Levels of DOM for Crypto is not sufficient and hopefully this can change in the future. |
[2018-04-20 07:42:40] |
User952186 - Posts: 58 |
Hi, I'm trying to chart Bitfinex BCHUSD pair. I can't view historical data before 01.22.2018 I followed documentation below, but It is still same. Historical Intraday Data (Missing Data / Download Errors / Viewing More Data) Could you please let me know what to do? Thanks. |
[2018-04-20 08:08:50] |
There is not historical data earlier for this particular symbol.
