Date/Time: Tue, 07 May 2024 21:02:50 +0000
Select all drawings on chart to move/ajdust them all at once - request
View Count: 1542
[2013-09-12 12:35:46] |
User59042 - Posts: 22 |
Hi Sierra, is there option to select all drawings and adjust them by xx points/ticks according to one's need? I would find it very useful when traders have to do rollover and adjust data by several points because of contract spread. I would like to easily move all drawings all at once. Could you look into it and see if it is possible? Thank you, Petr |
[2013-09-13 11:03:08] |
4646ed - Posts: 230 |
I agree. A global selection tool like in other windows programs.
[2013-09-14 18:42:24] |
Trakot57 - Posts: 8 |
I would also find this improvement very helpfull.
[2013-09-17 05:21:19] |
This will be looked at later on. Probably not until next year before this is gotten to.
