Date/Time: Fri, 13 Nov 2026 05:17:11 +0000
Trailing stop
View Count: 2749
| [2017-11-07 15:24:13] |
| User859795 - Posts: 51 |
Hello, So i’m still brand new to Sierra Chart and with your help now i’m at the point where i was able to set up and trade on the charts. I’d like to use the Super Trend Stop or Kiwi’s Stop studies as a trailing stop attached to my OCO order (i usually have 1 or 2 targets with BE at the first target), so i’d like to trail the stop order according to the Super Trend. I’m using server side OCO orders - as CQG supports it. Can you please help me to understand how to attach the Super Trend to the stop order? Thank you, Zolie |
| [2017-11-07 19:16:01] |
Refer to: Attached Orders: Study Controlled Targets and Stops Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-11-07 20:36:09] |
Hello, I adjusted the settings according to the post, I also added "Super Trend Stop" as the study to follow, so at Trade Management window I set "Controlling Subgraph Reference" to Super Trend Stop - Stop (SG1). However, it doesn't trail my stoploss and the stop order doesn't move. The trade Management study is set to Enabled. I'm using single bracket order with attached stop and targets, is that the problem? Thank you, Zolie |
| [2017-11-08 04:05:12] |
To determine what the problem is set the Detailed Logging Input to Yes. Here are instructions: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
