Date/Time: Mon, 29 Apr 2024 13:41:50 +0000
Merging SC historical intraday data with realtime datafeed from ZenFire
View Count: 1250
[2013-09-11 19:48:47] |
Peter Power - Posts: 70 |
I downloaded historical tick data from SC and would like to merge them with current datafeed from Zenfire in one chart. Is it really necesarry to run two copies of SC for that? The data is already downloaded from SC server so I donĀ“t need them to be updated. I just need to merge the expired months with current datafeed from ZenFire. Thanx |
[2013-09-11 22:07:57] |
You do not need to run a separate copy. You can change the Service within a copy. You will need to rename the data files to match the symbol used by ZenFire. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
