Date/Time: Sun, 28 Apr 2024 08:04:24 +0000
Copy chart drawings
View Count: 2047
[2013-04-04 13:04:53] |
sierrartb - Posts: 11 |
Hello, please let me know, how can I copy chart drawings to the chart, which is used as a study for another chart? Thank you. Richard |
[2013-04-04 16:19:47] |
So did you want to copy Chart Drawings drawn with the tools on the Tools menu?
[2013-04-05 07:31:31] |
No, I want to use chart settings - advanced settings 2 - copy chart drawings from chart...
[2013-04-05 07:35:04] |
We are not understanding the question.
[2013-04-05 08:13:28] |
Hello, I need to copy drawings from this chart http://www.sierrachart.com/image.php?l=1365149492142.png into this one http://www.sierrachart.com/image.php?l=1365149522833.png |
sierra.jpg / V - Attached On 2013-04-05 07:59:18 UTC - Size: 175.46 KB - 644 views sierra1.jpg / V - Attached On 2013-04-05 08:08:18 UTC - Size: 165.12 KB - 606 views Attachment Deleted. |
[2021-04-13 14:54:05] |
User525965 - Posts: 153 |
Hi, is there a way to copy drawings from a chart on 1 workspace to a chart on another workspace? Follow up question, what is the file name that stores the chart drawings? If, for example I want to copy the drawings I have on a chart to another Sierra chart instance, would there be an easy way to do that each morning? Thanks! |
[2021-04-13 15:17:42] |
Refer to the information regarding copying to a different chartbook here: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) what is the file name that stores the chart drawings? If, for example I want to copy the drawings I have on a chart to another Sierra chart instance, would there be an easy way to do that each morning?
The drawings are stored with the chart in the Chartbooks. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-13 15:25:41] |
thanks, so I would just need to copy the chart file ( .cht in the data folder)? |
[2021-04-13 16:37:49] |
Yes, you can copy the .cht file, which is a Chartbook file. Just be sure Sierra Chart is not running on the system when you copy or paste it. Also, understand that if a chartbook with the same name already exists it will overwrite it and you will lose the information that was in the file that was overwritten. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-14 14:48:39] |
got it, will it change the symbol as well? if i'm using 2 diff brokers..
[2021-04-14 15:19:04] |
No, it will not automatically update the symbols. But once you open the copied Chartbook just select Edit >> Translate Symbols to Current Service and that will change all the symbols within the Chartbook for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
