Date/Time: Tue, 16 Jun 2026 03:29:43 +0000
[User Discussion] - Correlation Chart
View Count: 4124
[2013-04-04 13:04:13]
Arnold - Posts: 20
Have you guys developed a new SC version that would allow me to easily derive a correlation chart?
Arnold
[2013-04-04 21:45:55]
We have not made any changes with this, however these kinds of calculations are possible. We are not certain what the formula is you need to do for the correlation calculation. Could you let us know.
[2013-04-05 12:58:18]
Arnold - Posts: 20
I want to overlay ES, YM, NQ, CL, DX onto the very same chart so as to note if all instruments are in synch with each other. There seems to be no easy way...as yet.
Arnold
[2013-04-05 20:53:48]
In this case, you just need to use the Overlay (Bar or Single Line) study. This is easy.
[2013-04-09 14:18:26]
Arnold - Posts: 20
And how do I identify each instrument once I use the non synch overlay bar
[2013-04-10 03:25:40]
We recommend using the Overlay ( Single Line) study. And on the first Subgraph set a Name Label and change the name of it through the Short Name for the Subgraph. Refer to:
http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#NameValueLabels
