Date/Time: Sat, 18 May 2024 03:52:56 +0000
support/resistance zones indicator
View Count: 4962
[2017-10-30 16:00:37] |
Glenn Infinity - Posts: 103 |
below is from a customer...do you guys provide these or do you have any suggestions? He came to us at the suggestion of an educator and wanted to use Sierra specifically Just one question – for Ninja trader, I purchased a support/resistance zones indicator from Indicator Warehouse, and it was great, but not available for Sierra. In fact, the only one I can find for Sierra is at https://apazones.com/apaforsierra-2. It’s called APA Elements. Have you heard any comments about it, or do you know of another one? None of the available studies seem to plot the S/R zones. |
[2017-10-30 16:40:03] |
How are these support and resistance zones calculated?
[2017-10-31 19:28:38] |
mkata - Posts: 103 |
These zones are mostly swing high/low (a few others are inside bar).
[2017-11-01 04:54:01] |
Here is the documentation for the Swing High and Low study: Swing High and Low And the Inside Bar study: Inside Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
