Date/Time: Sat, 04 May 2024 00:26:44 +0000
how tp specify Bitmex leverage?
View Count: 2124
[2017-10-27 10:47:07] |
User610670 - Posts: 1 |
I would like to specify 25x leverage on orders to Bitmex, But I can not find an option to do that anywhere?
[2017-10-27 18:27:13] |
You need to contact BitMEX about this. There would be no way to specify this in Sierra Chart.
[2017-10-27 18:31:57] |
BitMEX_Sam - Posts: 7 |
Hi User610670, Unfortunately there is no control in the Sierra Chart client for this. We recommend you use the web interface to adjust your leverage, then continue trading in Sierra Chart. |
[2018-02-16 02:34:25] |
User342238 - Posts: 44 |
HI, I am just demoing and finding that I can only enter orders in 1 dollar increments, one contract on the dom is equivalent to purchasing one dollar of bitcoin. How do I adjust the quantity? |
[2018-02-16 02:44:17] |
You can't trade fractional contracts on BitMEX, so contract sizes are generally set low to accommodate this.
[2018-02-16 02:57:11] |
So using the Sierra Dom, how would I enter an order to purchase say 100k usd worth of bitcoin... If I select one contract and put an order in I get a position of 1 usd...
[2018-02-16 03:13:48] |
You would select 100,000 contracts to do that.
[2018-02-16 03:33:13] |
great, see it now, thanks...
[2018-03-21 21:40:10] |
User952186 - Posts: 58 |
Is there a plan to add leverage setting inside Sierra for Bitmex If it is technically possible? Thanks. Ozgur |
[2018-03-22 03:36:05] |
If it is an execution instruction it would be possible. We would have to look into this.
[2018-03-22 08:09:50] |
Thank you for immediate response. I hope It will be added soon. Regards |
[2018-04-27 08:16:37] |
Hi again, have you had a chance to look at it? Thanks. |
[2018-04-27 23:24:28] |
Not yet but we should be getting to this in the next couple of weeks.
[2018-05-11 21:40:48] |
User308138 - Posts: 17 |
hello any updates on this?
[2018-05-14 18:24:12] |
In regards to: Is there a plan to add leverage setting inside Sierra for Bitmex If it is technically possible? This is more involved than expected, so we have not done anything with this yet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-16 19:40:48] |
what about atleast showing what leverage option is selected in the website? so we know at what leverage we are trading at
[2018-05-16 20:40:57] |
That is not going to come at all.
