Date/Time: Thu, 02 May 2024 00:36:18 +0000
Market Depth Combine Increment in Ticks.
View Count: 1807
[2017-10-27 03:42:15] |
N!co - Posts: 140 |
Hi, the new option Chart >> Chart Settings >> Advanced Settings 3 >> Market Depth Combine Increment in Ticks. is only working for the BID and ASK prices could you please make it work for the other Customize chart /trade DOM options like , current traded bid/ask , market depth pulling/stacking .. thank you |
marketdepth.png / V - Attached On 2017-10-27 03:41:58 UTC - Size: 148.66 KB - 694 views |
[2017-10-27 07:49:52] |
Spinoza - Posts: 62 |
+1
[2017-10-30 15:02:44] |
N!co - Posts: 140 |
support , have you looked into this issue ?
[2021-04-03 14:41:02] |
artlen - Posts: 1 |
I have the same issue. Have you resolved it?
[2021-04-05 13:55:20] |
The Combine Increment will not support the other market data columns. That is not easily changed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-05 13:55:29
[2021-04-05 14:40:49] |
User877753 - Posts: 152 |
I support this request too ...
Attachment Deleted. 2021-04-05 16_39_48.png / V - Attached On 2021-04-05 14:40:17 UTC - Size: 65.39 KB - 271 views |
[2021-04-13 18:57:16] |
Zosimus - Posts: 345 |
+1
[2021-04-13 19:13:19] |
SC team, could you please direct me to the documentation of the method that is used to increment the market depth? I would like to code incrementing of the Pull/Stack values and want it to be in line with the market depth increments. |
[2021-04-13 19:27:23] |
John - SC Support - Posts: 31293 |
The closest information that is available is in this documentation: Market Depth Historical Graph: Combine Increment in Ticks Additional Information For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-20 16:55:55] |
Wernitschanton - Posts: 14 |
+1 would be really helpful to be able to increment the pull/stack column too =)
