Date/Time: Tue, 07 May 2024 09:12:47 +0000
[Programming Help] - Disable Spreadsheet Trading
View Count: 1646
[2017-10-26 01:54:43] |
User104854 - Posts: 441 |
I just put together a simple spreadsheet to automate my exits. I do not see how I can enable or disable the spreadsheet as sometimes I want it active and other times not. I know it can be programmed to be active at certain times and all that but I just simply want to manually disable and enable it. Please advise on how to do this. Thank you.
[2017-10-26 20:09:50] |
Here is the documentation for this: Spreadsheet Systems, Alerts and Automated Trading: Halting Order Entry You basically will want to use the Trade >> Auto Trading Enabled commands. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-26 20:10:21
[2017-10-26 22:19:01] |
Ok. Thank you for the reply. If I disable auto trading will that affect attached orders or the 'trade management by study' study?
[2017-10-26 22:53:26] |
It will not affect Attached Orders but it will stop trading from the Trade Management by Study study. But what you can do is use Trade >> Auto Trading Enabled - Chart to disable automated trading for an individual chart. In this case, trading related studies in other charts will not be affected. We will update the documentation about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-11 22:41:21
[2017-10-26 23:35:24] |
Sawtooth - Posts: 3993 |
You can also use cell J28. Enter a 1 and the autotrading will be disabled for the respective chart. You can also reference a more convenient cell: Enter 1 in cell H1. Enter =H1 in cell J28. |
[2017-10-27 05:26:46] |
Perfect. Thanks a lot Tom.
[2019-02-10 04:32:59] |
User917679 - Posts: 76 |
Is there a way to disable/enable 'trade management by study' through the spreadsheet study?
Date Time Of Last Edit: 2019-02-10 04:33:14
[2019-02-10 04:54:14] |
Not directly, but if the formula it references returns a zero, the Trade Management by Study will do nothing.
[2019-02-10 14:28:35] |
Is it possible to change the subgraph input that is referenced by TMbS through spreadsheet? In other words, can you change TMbS' (In:3) via spreadsheet? |
[2019-02-10 16:29:59] |
No, but you can use multiple instances of the Trade Management by Study study, that each reference a different subgraph.
