Date/Time: Tue, 07 May 2024 11:21:48 +0000
Historical tick data from ZenFire
View Count: 1804
[2013-09-10 20:55:41] |
Peter Power - Posts: 70 |
Hello, I am currently in a phase when I am switching from NinjaTrader to SierraChart. 1) I need to plot a chart where I can see the actual price movement but also goes at least 1 year (preferably 2) in history and has to be build from tick data. I need it to plot composite profile. I am using Zen-Fire. Is there a way how it can be done? 2) How much of historical tick data will Zen-Fire provide? 3) I tried also to import my historical data from NT but the chart looked weird. Do I need to adjust the txt exportet file from NT somehow to make it work with Sierra. I found the data format between one of the supported formats here: http://www.sierrachart.com/index.php?l=doc/doc_TextCSVDataFormat.html |
[2013-09-10 23:39:29] |
1. Not with the data provided by Zen-Fire. You could use IQ Feed data for this or wait for the upcoming Sierra Chart futures CME data feed which will support this. Refer to these pages: https://www.sierrachart.com/index.php?l=doc/MultipleServices.html https://www.sierrachart.com/index.php?l=doc/DTNIQFeed.html 2. None. 3. Post about 30 or so lines of the historical data you have so we can look at it. What is the time zone of that data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-11 07:36:19] |
Thanx for answer. 1) When is SC futures CME data feed out? 2) Are you sure about this? 3) 20130818 230001;1650.75;1 20130818 230001;1650.5;1 20130818 230001;1650.5;1 20130818 230001;1650.75;5 20130818 230003;1650.75;1 20130818 230006;1650.75;27 20130818 230006;1650.75;3 20130818 230006;1650.75;3 20130818 230006;1650.75;3 20130818 230006;1650.75;39 20130818 230006;1650.75;3 20130818 230006;1650.75;3 20130818 230006;1650.75;3 20130818 230006;1650.75;1 20130818 230006;1650.75;1 20130818 230006;1650.75;3 20130818 230133;1650.75;1 20130818 230218;1651;1 20130818 230306;1651;1 20130818 230310;1651;10 20130818 230312;1651;1 20130818 230327;1651;1 20130818 230333;1650.75;1 20130818 230333;1650.75;1 20130818 230333;1650.75;1 20130818 230333;1650.75;1 20130818 230333;1650.75;3 20130818 230333;1650.75;1 20130818 230333;1650.75;2 20130818 230341;1650.75;1 |
[2013-09-11 22:32:35] |
1. 45 days 2. Yes 3. This is not a supported format. There needs to be a comma between the date and time. Refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_TextCSVDataFormat.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-11 22:35:48
