Date/Time: Thu, 02 May 2024 06:56:26 +0000
Question
View Count: 1187
[2013-09-10 18:21:02] |
p20720 - Posts: 3 |
Dear SC Support, I wonder if SC has made a recent change to its software or to a feature of the Number Bars Calculated Values study because that feature used to work Ok in previous SC versions, is not working properly right now. The feature is include prior bar common price volume. I am using ver. 1022. Is it perhaps a floating point issue? Because the problem happens at bar edges and only in many of the charts where the tick values are in decimal places. Thanks. |
[2013-09-10 18:25:17] |
We will have to look into this. There has been no recent changes with the Numbers Bars Calculated Values study.
