Date/Time: Fri, 13 Nov 2026 05:35:13 +0000
keep getting disconnected
View Count: 1206
| [2017-10-18 16:24:07] |
| tilly - Posts: 8 |
Reading Internal Order ID file. | 2017-10-18 08:28:00 Reading Trade Orders file. | 2017-10-18 08:28:00 Reading Trade Positions file. | 2017-10-18 08:28:00 Listening on UDP port 22903. | 2017-10-18 08:28:00 Software version: 1580 | 2017-10-18 08:28:00 Uses New Spreadsheets | 2017-10-18 08:28:00 Usage end date: 2017-11-05 | 2017-10-18 08:28:00 Enabled for: Advanced Features. | 2017-10-18 08:28:00 Enabled for: Sierra Chart Historical Data Service. | 2017-10-18 08:28:00 Allow Support for Sierra Chart Data Feeds is disabled. | 2017-10-18 08:28:00 Current selected Data/Trading service: CTS T4 FIX | 2017-10-18 08:28:00 Chart Update Interval: 40 | 2017-10-18 08:28:00 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-10-18 08:28:00 2017-10-18 08:28:22 Local computer time | 2017-10-18 08:28:00 2017-10-18 13:28:22 Local computer time in UTC | 2017-10-18 08:28:00 2017-10-18 08:28:22 Local computer time in SC Time Zone | 2017-10-18 08:28:00 Program path: F:\SierraChart\ | 2017-10-18 08:28:00 Data Files path: F:\SierraChart\Data\ | 2017-10-18 08:28:00 OS Version Number: 6.1 | 2017-10-18 08:28:00 Locale Setting: C | 2017-10-18 08:28:00 Checking for new symbol settings for service code cts | 2017-10-18 08:28:00 HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2017-10-18 08:28:00 HTTPS connection to www.sierrachart.com:443 (3) | Connecting to IP: 204.15.192.108. | 2017-10-18 08:28:00 Symbol settings are up-to-date for cts | 2017-10-18 08:28:00 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-18 08:28:27 CTS T4 FIX | Firm: Dorman | 2017-10-18 08:28:27 CTS FIX socket (4) | Creating socket. Using TLS 1.0. | 2017-10-18 08:28:27 CTS FIX socket (4) | Connecting to IP: 208.116.215.102. | 2017-10-18 08:28:27 HTTPS connection to www.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2017-10-18 08:28:27 HTTPS connection to www.sierrachart.com:443 (3) | Received socket Close event | 2017-10-18 08:28:27 HTTPS connection to www.sierrachart.com:443 (3) | Initiating close of socket by core. | 2017-10-18 08:28:27 HTTPS connection to www.sierrachart.com:443 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-18 08:28:27 HTTPS connection to www.sierrachart.com:443 (3) | Closed. | 2017-10-18 08:28:27 CTS FIX socket (4) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-10-18 08:28:48 * CTS FIX socket (4) | Initiating close of socket by core. | 2017-10-18 08:28:48 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-10-18 08:28:48 CTS FIX socket (4) | Closed. | 2017-10-18 08:28:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-18 08:28:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:28:48 CTS T4 FIX | Disconnected. | 2017-10-18 08:28:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:28:48 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-18 08:28:51 CTS T4 FIX | Firm: Dorman | 2017-10-18 08:28:51 CTS FIX socket (5) | Creating socket. Using TLS 1.0. | 2017-10-18 08:28:51 CTS FIX socket (5) | Connecting to IP: 208.116.215.102. | 2017-10-18 08:28:51 CTS FIX socket (5) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-10-18 08:29:12 * CTS FIX socket (5) | Initiating close of socket by core. | 2017-10-18 08:29:12 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-10-18 08:29:12 CTS FIX socket (5) | Closed. | 2017-10-18 08:29:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-18 08:29:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:29:12 CTS T4 FIX | Disconnected. | 2017-10-18 08:29:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:29:12 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-18 08:29:15 CTS T4 FIX | Firm: Dorman | 2017-10-18 08:29:15 CTS FIX socket (6) | Creating socket. Using TLS 1.0. | 2017-10-18 08:29:15 CTS FIX socket (6) | Connecting to IP: 74.201.6.106. | 2017-10-18 08:29:15 CTS FIX: Sending the Logon message. | 2017-10-18 08:29:16 CTS T4 FIX | FIX version: 4.3.73.5 | 2017-10-18 08:29:16 CTS T4 FIX | Connected to data and trading server. | 2017-10-18 08:29:16 CTS T4 FIX | Received Account List collateral report. | 2017-10-18 08:29:16 CTS T4 FIX | Subscribing to account: 460* | 2017-10-18 08:29:16 Supported exchange: L_J (Euronext Index Futures) | 2017-10-18 08:29:16 Supported exchange: ICE_IC (ICE EU Futures) | 2017-10-18 08:29:16 Supported exchange: L_Y (Euronext Commodity Futures) | 2017-10-18 08:29:16 Supported exchange: CME_ELE (NYMEX Power Futures) | 2017-10-18 08:29:16 Supported exchange: SGX_COp (SGX Commodity Options) | 2017-10-18 08:29:16 Supported exchange: ICE_WOp (ICE Canada Options) | 2017-10-18 08:29:16 Supported exchange: L_YOp (Euronext Commodity Options) | 2017-10-18 08:29:16 Supported exchange: E_INXOp (Eurex Index Options) | 2017-10-18 08:29:16 Supported exchange: CME_FRE (NYMEX Freight Futures) | 2017-10-18 08:29:16 Supported exchange: CME_KOp (KCBT Options) | 2017-10-18 08:29:16 Supported exchange: CME_HoOp (CME Housing Options) | 2017-10-18 08:29:16 Supported exchange: E_FITOp (Eurex Interest Rate Options) | 2017-10-18 08:29:16 Supported exchange: ICE_ICOp (ICE EU Options) | 2017-10-18 08:29:16 Supported exchange: ICE_FOp (ICE EU Financial Options) | 2017-10-18 08:29:16 Supported exchange: ICE_CO (ICE US Commodity Futures) | 2017-10-18 08:29:16 Supported exchange: CME_COAL (NYMEX Coal Futures) | 2017-10-18 08:29:16 Supported exchange: CME_COp (CBOT Commodity Options) | 2017-10-18 08:29:16 Supported exchange: SGX_C (SGX Commodity Futures) | 2017-10-18 08:29:16 Supported exchange: CME_EqOp (CME Equity Options) | 2017-10-18 08:29:16 Supported exchange: E_VOL (Eurex Volatility Futures) | 2017-10-18 08:29:16 Supported exchange: CME_CL (NYMEX CrudeOil Futures) | 2017-10-18 08:29:16 Supported exchange: ICE_IN (ICE US Index Futures) | 2017-10-18 08:29:16 Supported exchange: CME_Fo (CME Foreign Exchange Futures) | 2017-10-18 08:29:16 Supported exchange: CME_Ho (CME Housing Futures) | 2017-10-18 08:29:16 Supported exchange: ICE_INOp (ICE US Index Options) | 2017-10-18 08:29:16 Supported exchange: CME_AgOp (CME Agricultural Options) | 2017-10-18 08:29:16 Supported exchange: CME_In (CME Interest Rate Futures) | 2017-10-18 08:29:16 Supported exchange: E_CUR (Eurex Currency Futures) | 2017-10-18 08:29:16 Supported exchange: E_FBDOp (Eurex Fixed Income Options) | 2017-10-18 08:29:16 Supported exchange: CME_CO (COMEX Futures) | 2017-10-18 08:29:16 Supported exchange: CME_Ag (CME Agricultural Futures) | 2017-10-18 08:29:16 Supported exchange: CME_EOp (CBOT Equity Options) | 2017-10-18 08:29:16 Supported exchange: CME_C (CBOT Commodity Futures) | 2017-10-18 08:29:16 Supported exchange: CME_F (CBOT Financial Futures) | 2017-10-18 08:29:16 Supported exchange: CME_E (CBOT Equity Futures) | 2017-10-18 08:29:16 Supported exchange: CME_K (KCBT Futures) | 2017-10-18 08:29:16 Supported exchange: CME_O (MGEX Futures) | 2017-10-18 08:29:16 Supported exchange: LME_PR (LME Precious Metal Futures) | 2017-10-18 08:29:16 Supported exchange: CME_FOp (CBOT Financial Options) | 2017-10-18 08:29:16 Supported exchange: ICE_MOp (ICE US Metals Options) | 2017-10-18 08:29:16 Supported exchange: E_FIXOp (E_FIXOp) | 2017-10-18 08:29:16 Supported exchange: E_INX (Eurex Index Futures) | 2017-10-18 08:29:16 Supported exchange: ICE_M (ICE US Metals Futures) | 2017-10-18 08:29:16 Supported exchange: CME_OOp (MGEX Options) | 2017-10-18 08:29:16 Supported exchange: CME_COALOp (NYMEX Coal Options) | 2017-10-18 08:29:16 Supported exchange: ICE_CU (ICE US Currency Futures) | 2017-10-18 08:29:16 Supported exchange: ICE_C (ICE EU Commodity Futures) | 2017-10-18 08:29:16 Supported exchange: CME_NG (NYMEX NatGas Futures) | 2017-10-18 08:29:16 Supported exchange: CME_CLOp (NYMEX CrudeOil Options) | 2017-10-18 08:29:16 Supported exchange: E_INT (Eurex Interest Rate Futures) | 2017-10-18 08:29:16 Supported exchange: ICE_F (ICE EU Financial Futures) | 2017-10-18 08:29:16 Supported exchange: CME_NYOp (NYMEX Options) | 2017-10-18 08:29:16 Supported exchange: CME_We (CME Weather Futures) | 2017-10-18 08:29:16 Supported exchange: CME_REFOp (NYMEX Refined Products Options) | 2017-10-18 08:29:16 Supported exchange: CME_PET (NYMEX NGL/Petrochemicals Futures) | 2017-10-18 08:29:16 Supported exchange: ICE_W (ICE Canada Futures) | 2017-10-18 08:29:16 Supported exchange: ICE_COOp (ICE US Commodity Options) | 2017-10-18 08:29:16 Supported exchange: E_CUROp (Eurex Currency Options) | 2017-10-18 08:29:16 Supported exchange: CME_PETOp (NYMEX NGL/Petrochemicals Options) | 2017-10-18 08:29:16 Supported exchange: E_BND (Eurex Fixed Income Futures) | 2017-10-18 08:29:16 Supported exchange: CME_COOp (COMEX Options) | 2017-10-18 08:29:16 Supported exchange: LME_ME (LME Metal Futures) | 2017-10-18 08:29:16 Supported exchange: LME_PL (LME Plastic Futures) | 2017-10-18 08:29:16 Supported exchange: ICE_COp (ICE EU Commodity Options) | 2017-10-18 08:29:16 Supported exchange: CME_InOp (CME Interest Rate Options) | 2017-10-18 08:29:16 Supported exchange: CME_FREOp (NYMEX Freight Options) | 2017-10-18 08:29:16 Supported exchange: CME_ELEOp (NYMEX Power Options) | 2017-10-18 08:29:16 Supported exchange: CME_Eq (CME Equity Futures) | 2017-10-18 08:29:16 Supported exchange: CBOE_CFE (CFE) | 2017-10-18 08:29:16 Supported exchange: CME_NGOp (NYMEX NatGas Options) | 2017-10-18 08:29:16 Supported exchange: CME_NY (NYMEX Futures) | 2017-10-18 08:29:16 Supported exchange: CME_FoOp (CME Foreign Exchange Options) | 2017-10-18 08:29:16 Supported exchange: CME_REF (NYMEX Refined Products Futures) | 2017-10-18 08:29:16 Supported exchange: LME_IN (LME Index Futures) | 2017-10-18 08:29:16 CTS T4 FIX | Received unsolicited security definition for symbol ES.20171200.CME_Eq. Making full security definition request for additional details. | 2017-10-18 08:29:19 CTS T4 FIX | Received unsolicited security definition for symbol ES.20170900.CME_Eq. Making full security definition request for additional details. | 2017-10-18 08:29:19 CTS T4 FIX | Received unsolicited security definition for symbol 6E.20170900.CME_Fo. Making full security definition request for additional details. | 2017-10-18 08:29:19 CTS T4 FIX | Received unsolicited security definition for symbol 6E.20171200.CME_Fo. Making full security definition request for additional details. | 2017-10-18 08:29:19 CTS T4 FIX | Received Account Details collateral report for account: 46097 | 2017-10-18 08:29:19 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-10-18 08:29:19 CTS T4 FIX | Sending security definition request for symbol 6E.20170900.CME_Fo | 2017-10-18 08:29:20 Symbol Error - 6E.20170900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-10-18 08:29:20 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-10-18 08:29:20 CTS T4 FIX | Requesting Open Orders for account: 460*. Request ID: 1540771 | 2017-10-18 08:29:21 CTS T4 FIX | No open orders for account 46097 | 2017-10-18 08:29:21 CTS T4 FIX | Sending security definition request for symbol 6E.20171200.CME_Fo | 2017-10-18 08:29:21 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-10-18 08:29:21 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-18 08:29:21 Contract specifications for 6E.20171200.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-10-18 08:29:21 CTS T4 FIX | Sending security definition request for symbol ES.20170900.CME_Eq | 2017-10-18 08:29:23 Symbol Error - ES.20170900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-10-18 08:29:23 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-10-18 08:29:23 CTS T4 FIX | Sending security definition request for symbol ES.20171200.CME_Eq | 2017-10-18 08:29:24 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-10-18 08:29:24 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-18 08:29:24 Contract specifications for ES.20171200.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-10-18 08:29:24 CTS T4 FIX | Requesting historical Fills for account: 460*. Request ID: 1540774 | 2017-10-18 08:29:31 CTS T4 FIX | Received Account List collateral report. | 2017-10-18 08:29:31 CTS T4 FIX | Server provided no historical order fills for account 250395C5-931E-4E6C-9045-9D7B7F369BBA | 2017-10-18 08:29:31 ES.20171200.CME_Eq 233 Trades #2 | Reloading chart. | 2017-10-18 08:35:04 6E.20171200.CME_Fo 25 Min #4 | Reloading chart. | 2017-10-18 08:35:04 6E.20171200.CME_Fo 3 Min #8 | Reloading chart. | 2017-10-18 08:35:04 ES.20171200.CME_Eq 512 Trades #12 | Reloading chart. | 2017-10-18 08:35:04 6E.20171200.CME_Fo 15 Min #1 | Reloading chart. | 2017-10-18 08:35:04 ES.20171200.CME_Eq 25 Min #14 | Reloading chart. | 2017-10-18 08:35:04 ES.20171200.CME_Eq 5000 Trades #13 | Reloading chart. | 2017-10-18 08:35:04 ES.20171200.CME_Eq 5 Min #18 | Reloading chart. | 2017-10-18 08:35:04 ES.20171200.CME_Eq 15 Min #21 | Reloading chart. | 2017-10-18 08:35:04 ES.20171200.CME_Eq 2000 Trades #22 | Reloading chart. | 2017-10-18 08:35:04 6E.20171200.CME_Fo 1600 Trades #25 | Reloading chart. | 2017-10-18 08:35:04 ES.20171200.CME_Eq 3200 Trades #7 | Reloading chart. | 2017-10-18 08:35:04 6E.20171200.CME_Fo 5 Min #9 | Reloading chart. | 2017-10-18 08:35:04 6E.20171200.CME_Fo 1600 Trades #11 | Reloading chart. | 2017-10-18 08:35:04 ES.20171200.CME_Eq 15 Min #5 | Reloading chart. | 2017-10-18 08:35:04 6E.20171200.CME_Fo 1 Min #6 | Reloading chart. | 2017-10-18 08:35:04 6E.20171200.CME_Fo 233 Trades #10 | Reloading chart. | 2017-10-18 08:35:04 6E.20171200.CME_Fo 133 Trades #3 | Reloading chart. | 2017-10-18 08:35:04 6E.20171200.CME_Fo 512 Trades #16 | Reloading chart. | 2017-10-18 08:35:04 6E.20171200.CME_Fo 15 Min #15 | Reloading chart. | 2017-10-18 08:35:04 ES.20171200.CME_Eq 512 Trades #19 | Reloading chart. | 2017-10-18 08:35:04 ES.20171200.CME_Eq 60 Min #17 | Reloading chart. | 2017-10-18 08:35:04 CTS T4 FIX | Starting real-time market data updates for: ES.20171200.CME_Eq. ID: 2 | 2017-10-18 08:35:04 CTS T4 FIX | Requesting security definition data for: ES.20171200.CME_Eq. ID: 2 | 2017-10-18 08:35:04 CTS T4 FIX | Using primary service for historical data for ES.20171200.CME_Eq | 2017-10-18 08:35:04 Intraday data recording state for symbol ES.20171200.CME_Eq is set to download 'Pending'. | 2017-10-18 08:35:04 Delaying start of download for ES.20171200.CME_Eq | 2017-10-18 08:35:04 CTS T4 FIX | Starting real-time market data updates for: 6E.20171200.CME_Fo. ID: 1 | 2017-10-18 08:35:04 CTS T4 FIX | Requesting security definition data for: 6E.20171200.CME_Fo. ID: 1 | 2017-10-18 08:35:04 CTS T4 FIX | Using primary service for historical data for 6E.20171200.CME_Fo | 2017-10-18 08:35:04 Intraday data recording state for symbol 6E.20171200.CME_Fo is set to download 'Pending'. | 2017-10-18 08:35:04 Delaying start of download for ES.20171200.CME_Eq | 2017-10-18 08:35:06 HD Request # 2 | Downloading Intraday chart data for ES.20171200.CME_Eq to the file ES.20171200.CME_Eq.scid. Service: cts | 2017-10-18 08:35:08 HD Request # 2 | Download start date-time: 2017-10-18 02:29:21.000 | 2017-10-18 08:35:08 CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2017-10-18 08:35:08 CTS FIX Historical Data socket (9) | Creating socket. Using TLS 1.0. | 2017-10-18 08:35:08 CTS FIX Historical Data socket (9) | Connecting to IP: 69.44.110.227. | 2017-10-18 08:35:08 CTS FIX Historical Data: Sending the Logon message. | 2017-10-18 08:35:09 CTS FIX Historical Data: Connected to Historical data server. | 2017-10-18 08:35:09 HD Request # 2 | Requesting historical Tick data for ES.20171200.CME_Eq from 2017-10-18 00:00:00 to 2017-10-18 00:00:00 (US Central Time). | 2017-10-18 08:35:09 HD Request # 2 | Receiving Intraday data for ES.20171200.CME_Eq starting at 2017-10-17 17:00:00 | 2017-10-18 08:35:09 HD Request # 2 | Timestamp of first Intraday data file record written: 2017-10-18 02:29:24 | 2017-10-18 08:35:09 HD Request # 2 | Total records received: 44918 | 2017-10-18 08:35:09 HD Request # 2 | Requesting historical Tick data for ES.20171200.CME_Eq from 2017-10-19 00:00:00 to 2017-10-19 00:00:00 (US Central Time). | 2017-10-18 08:35:09 HD Request # 2 | Total records received: 44918 | 2017-10-18 08:35:09 HD Request # 2 | Requesting historical Tick data for ES.20171200.CME_Eq from 2017-10-20 00:00:00 to 2017-10-20 00:00:00 (US Central Time). | 2017-10-18 08:35:09 HD Request # 2 | Received 44918 records from 2017-10-17 17:00:00 to 2017-10-18 08:35:10 (15.6 hours) and wrote 31986 records for ES.20171200.CME_Eq | 2017-10-18 08:35:09 Added 8 Time and Sales records to Intraday data file for ES.20171200.CME_Eq after download. | 2017-10-18 08:35:09 HD Request # 2 | Intraday download COMPLETE for ES.20171200.CME_Eq. Completion time: 1s. Unique request ID: 1 | 2017-10-18 08:35:09 Removed historical data download ID 1 | 2017-10-18 08:35:09 Real-time Intraday chart data file updates started for ES.20171200.CME_Eq | 2017-10-18 08:35:09 Intraday chart data file opened for ES.20171200.CME_Eq | 2017-10-18 08:35:09 HD Request # 3 | Downloading Intraday chart data for 6E.20171200.CME_Fo to the file 6E.20171200.CME_Fo.scid. Service: cts | 2017-10-18 08:35:09 HD Request # 3 | Download start date-time: 2017-10-18 02:29:24.000 | 2017-10-18 08:35:09 HD Request # 3 | Requesting historical Tick data for 6E.20171200.CME_Fo from 2017-10-18 00:00:00 to 2017-10-18 00:00:00 (US Central Time). | 2017-10-18 08:35:09 HD Request # 3 | Receiving Intraday data for 6E.20171200.CME_Fo starting at 2017-10-17 17:00:00 | 2017-10-18 08:35:10 HD Request # 3 | Timestamp of first Intraday data file record written: 2017-10-18 02:29:25 | 2017-10-18 08:35:10 HD Request # 3 | Total records received: 70983 | 2017-10-18 08:35:10 HD Request # 3 | Requesting historical Tick data for 6E.20171200.CME_Fo from 2017-10-19 00:00:00 to 2017-10-19 00:00:00 (US Central Time). | 2017-10-18 08:35:10 HD Request # 3 | Total records received: 70983 | 2017-10-18 08:35:10 HD Request # 3 | Requesting historical Tick data for 6E.20171200.CME_Fo from 2017-10-20 00:00:00 to 2017-10-20 00:00:00 (US Central Time). | 2017-10-18 08:35:10 HD Request # 3 | Received 70983 records from 2017-10-17 17:00:00 to 2017-10-18 08:35:10 (15.6 hours) and wrote 49705 records for 6E.20171200.CME_Fo | 2017-10-18 08:35:10 HD Request # 3 | Intraday download COMPLETE for 6E.20171200.CME_Fo. Completion time: 1s. Unique request ID: 2 | 2017-10-18 08:35:10 Removed historical data download ID 2 | 2017-10-18 08:35:10 Real-time Intraday chart data file updates started for 6E.20171200.CME_Fo | 2017-10-18 08:35:10 Intraday chart data file opened for 6E.20171200.CME_Fo | 2017-10-18 08:35:10 Opened cached Intraday file: F:\SierraChart\Data\ES.20171200.CME_Eq.scid | 2017-10-18 08:35:14 Opened cached Intraday file: F:\SierraChart\Data\6E.20171200.CME_Fo.scid | 2017-10-18 08:35:24 CTS FIX Historical Data socket (9) | Socket gracefully closed by remote side. | 2017-10-18 08:36:10 CTS FIX Historical Data socket (9) | Received socket Close event | 2017-10-18 08:36:10 CTS FIX Historical Data socket (9) | Initiating close of socket by core. | 2017-10-18 08:36:10 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2017-10-18 08:36:10 CTS FIX Historical Data socket (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-18 08:36:10 CTS FIX Historical Data socket (9) | Closed. | 2017-10-18 08:36:10 CTS FIX Historical Data: Disconnected. | 2017-10-18 08:36:10 CTS FIX socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-18 08:48:37 * CTS FIX socket (6) | Socket gracefully closed by remote side. | 2017-10-18 08:48:37 CTS FIX socket (6) | Received socket Close event | 2017-10-18 08:48:37 CTS FIX socket (6) | Initiating close of socket by core. | 2017-10-18 08:48:37 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-10-18 08:48:37 CTS FIX socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-18 08:48:37 CTS FIX socket (6) | Closed. | 2017-10-18 08:48:37 Connection to the external service has been lost. | 2017-10-18 08:48:37 CTS T4 FIX | Disconnected. | 2017-10-18 08:48:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:48:37 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-18 08:48:40 CTS T4 FIX | Firm: Dorman | 2017-10-18 08:48:40 CTS FIX socket (14) | Creating socket. Using TLS 1.0. | 2017-10-18 08:48:42 CTS FIX socket (14) | Connecting to IP: 69.44.110.106. | 2017-10-18 08:48:42 CTS FIX socket (14) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-10-18 08:49:04 * CTS FIX socket (14) | Initiating close of socket by core. | 2017-10-18 08:49:04 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-10-18 08:49:04 CTS FIX socket (14) | Closed. | 2017-10-18 08:49:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-18 08:49:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:49:04 CTS T4 FIX | Disconnected. | 2017-10-18 08:49:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:49:04 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-18 08:49:07 CTS T4 FIX | Firm: Dorman | 2017-10-18 08:49:07 CTS FIX socket (15) | Creating socket. Using TLS 1.0. | 2017-10-18 08:49:11 CTS FIX socket (15) | Connecting to IP: 69.44.110.106. | 2017-10-18 08:49:11 CTS FIX: Sending the Logon message. | 2017-10-18 08:49:11 CTS T4 FIX | FIX version: 4.3.73.5 | 2017-10-18 08:49:12 CTS T4 FIX | Connected to data and trading server. | 2017-10-18 08:49:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-18 08:49:12 CTS T4 FIX | Starting real-time market data updates for: ES.20171200.CME_Eq. ID: 1 | 2017-10-18 08:49:12 CTS T4 FIX | Requesting security definition data for: ES.20171200.CME_Eq. ID: 1 | 2017-10-18 08:49:12 CTS T4 FIX | Using primary service for historical data for ES.20171200.CME_Eq | 2017-10-18 08:49:12 Intraday data recording state for symbol ES.20171200.CME_Eq is set to download 'Pending'. | 2017-10-18 08:49:12 Delaying start of download for ES.20171200.CME_Eq | 2017-10-18 08:49:12 CTS T4 FIX | Received Account List collateral report. | 2017-10-18 08:49:12 CTS T4 FIX | Subscribing to account: 460* | 2017-10-18 08:49:12 Supported exchange: L_J (Euronext Index Futures) | 2017-10-18 08:49:12 Supported exchange: ICE_IC (ICE EU Futures) | 2017-10-18 08:49:12 Supported exchange: L_Y (Euronext Commodity Futures) | 2017-10-18 08:49:12 Supported exchange: CME_ELE (NYMEX Power Futures) | 2017-10-18 08:49:12 Supported exchange: SGX_COp (SGX Commodity Options) | 2017-10-18 08:49:12 Supported exchange: ICE_WOp (ICE Canada Options) | 2017-10-18 08:49:12 Supported exchange: L_YOp (Euronext Commodity Options) | 2017-10-18 08:49:12 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-18 08:49:12 CTS T4 FIX | Starting real-time market data updates for: 6E.20171200.CME_Fo. ID: 2 | 2017-10-18 08:49:12 CTS T4 FIX | Requesting security definition data for: 6E.20171200.CME_Fo. ID: 2 | 2017-10-18 08:49:12 CTS T4 FIX | Using primary service for historical data for 6E.20171200.CME_Fo | 2017-10-18 08:49:12 Intraday data recording state for symbol 6E.20171200.CME_Fo is set to download 'Pending'. | 2017-10-18 08:49:12 Supported exchange: E_INXOp (Eurex Index Options) | 2017-10-18 08:49:12 Supported exchange: CME_FRE (NYMEX Freight Futures) | 2017-10-18 08:49:12 Supported exchange: CME_KOp (KCBT Options) | 2017-10-18 08:49:12 Supported exchange: CME_HoOp (CME Housing Options) | 2017-10-18 08:49:12 Supported exchange: E_FITOp (Eurex Interest Rate Options) | 2017-10-18 08:49:12 Supported exchange: ICE_ICOp (ICE EU Options) | 2017-10-18 08:49:12 Supported exchange: ICE_FOp (ICE EU Financial Options) | 2017-10-18 08:49:12 Supported exchange: ICE_CO (ICE US Commodity Futures) | 2017-10-18 08:49:12 Supported exchange: CME_COAL (NYMEX Coal Futures) | 2017-10-18 08:49:12 Supported exchange: CME_COp (CBOT Commodity Options) | 2017-10-18 08:49:12 Supported exchange: SGX_C (SGX Commodity Futures) | 2017-10-18 08:49:12 Supported exchange: CME_EqOp (CME Equity Options) | 2017-10-18 08:49:12 Supported exchange: E_VOL (Eurex Volatility Futures) | 2017-10-18 08:49:12 Supported exchange: CME_CL (NYMEX CrudeOil Futures) | 2017-10-18 08:49:12 Supported exchange: ICE_IN (ICE US Index Futures) | 2017-10-18 08:49:12 Supported exchange: CME_Fo (CME Foreign Exchange Futures) | 2017-10-18 08:49:12 Supported exchange: CME_Ho (CME Housing Futures) | 2017-10-18 08:49:12 Supported exchange: ICE_INOp (ICE US Index Options) | 2017-10-18 08:49:12 Supported exchange: CME_AgOp (CME Agricultural Options) | 2017-10-18 08:49:12 Supported exchange: CME_In (CME Interest Rate Futures) | 2017-10-18 08:49:12 Supported exchange: E_CUR (Eurex Currency Futures) | 2017-10-18 08:49:12 Supported exchange: E_FBDOp (Eurex Fixed Income Options) | 2017-10-18 08:49:12 Supported exchange: CME_CO (COMEX Futures) | 2017-10-18 08:49:12 Supported exchange: CME_Ag (CME Agricultural Futures) | 2017-10-18 08:49:12 Supported exchange: CME_EOp (CBOT Equity Options) | 2017-10-18 08:49:12 Supported exchange: CME_C (CBOT Commodity Futures) | 2017-10-18 08:49:12 Supported exchange: CME_F (CBOT Financial Futures) | 2017-10-18 08:49:12 Supported exchange: CME_E (CBOT Equity Futures) | 2017-10-18 08:49:12 Supported exchange: CME_K (KCBT Futures) | 2017-10-18 08:49:12 Supported exchange: CME_O (MGEX Futures) | 2017-10-18 08:49:12 Supported exchange: LME_PR (LME Precious Metal Futures) | 2017-10-18 08:49:12 Supported exchange: CME_FOp (CBOT Financial Options) | 2017-10-18 08:49:12 Supported exchange: ICE_MOp (ICE US Metals Options) | 2017-10-18 08:49:12 Supported exchange: E_FIXOp (E_FIXOp) | 2017-10-18 08:49:12 Supported exchange: E_INX (Eurex Index Futures) | 2017-10-18 08:49:12 Supported exchange: ICE_M (ICE US Metals Futures) | 2017-10-18 08:49:12 Supported exchange: CME_OOp (MGEX Options) | 2017-10-18 08:49:12 Supported exchange: CME_COALOp (NYMEX Coal Options) | 2017-10-18 08:49:12 Supported exchange: ICE_CU (ICE US Currency Futures) | 2017-10-18 08:49:12 Supported exchange: ICE_C (ICE EU Commodity Futures) | 2017-10-18 08:49:12 Supported exchange: CME_NG (NYMEX NatGas Futures) | 2017-10-18 08:49:12 Supported exchange: CME_CLOp (NYMEX CrudeOil Options) | 2017-10-18 08:49:12 Supported exchange: E_INT (Eurex Interest Rate Futures) | 2017-10-18 08:49:12 Supported exchange: ICE_F (ICE EU Financial Futures) | 2017-10-18 08:49:12 Supported exchange: CME_NYOp (NYMEX Options) | 2017-10-18 08:49:12 Supported exchange: CME_We (CME Weather Futures) | 2017-10-18 08:49:12 Supported exchange: CME_REFOp (NYMEX Refined Products Options) | 2017-10-18 08:49:12 Supported exchange: CME_PET (NYMEX NGL/Petrochemicals Futures) | 2017-10-18 08:49:12 Supported exchange: ICE_W (ICE Canada Futures) | 2017-10-18 08:49:12 Supported exchange: ICE_COOp (ICE US Commodity Options) | 2017-10-18 08:49:12 Supported exchange: E_CUROp (Eurex Currency Options) | 2017-10-18 08:49:12 Supported exchange: CME_PETOp (NYMEX NGL/Petrochemicals Options) | 2017-10-18 08:49:12 Supported exchange: E_BND (Eurex Fixed Income Futures) | 2017-10-18 08:49:12 Supported exchange: CME_COOp (COMEX Options) | 2017-10-18 08:49:12 Supported exchange: LME_ME (LME Metal Futures) | 2017-10-18 08:49:12 Supported exchange: LME_PL (LME Plastic Futures) | 2017-10-18 08:49:12 Supported exchange: ICE_COp (ICE EU Commodity Options) | 2017-10-18 08:49:12 Supported exchange: CME_InOp (CME Interest Rate Options) | 2017-10-18 08:49:12 Supported exchange: CME_FREOp (NYMEX Freight Options) | 2017-10-18 08:49:12 Supported exchange: CME_ELEOp (NYMEX Power Options) | 2017-10-18 08:49:12 Supported exchange: CME_Eq (CME Equity Futures) | 2017-10-18 08:49:12 Supported exchange: CBOE_CFE (CFE) | 2017-10-18 08:49:12 Supported exchange: CME_NGOp (NYMEX NatGas Options) | 2017-10-18 08:49:12 Supported exchange: CME_NY (NYMEX Futures) | 2017-10-18 08:49:12 Supported exchange: CME_FoOp (CME Foreign Exchange Options) | 2017-10-18 08:49:12 Supported exchange: CME_REF (NYMEX Refined Products Futures) | 2017-10-18 08:49:12 Supported exchange: LME_IN (LME Index Futures) | 2017-10-18 08:49:12 CTS T4 FIX | Sending security definition request for symbol 6E.20171200.CME_Fo | 2017-10-18 08:49:13 CTS T4 FIX | Received matching security definition for symbol 6E.20171200.CME_Fo. Subscribing to data. | 2017-10-18 08:49:13 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-10-18 08:49:13 Contract specifications for 6E.20171200.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-10-18 08:49:13 CTS T4 FIX | Sending security definition request for symbol ES.20171200.CME_Eq | 2017-10-18 08:49:14 CTS T4 FIX | Received unsolicited security definition for symbol ES.20171200.CME_Eq. Making full security definition request for additional details. | 2017-10-18 08:49:15 CTS T4 FIX | Received unsolicited security definition for symbol ES.20170900.CME_Eq. Making full security definition request for additional details. | 2017-10-18 08:49:15 CTS T4 FIX | Sending security definition request for symbol ES.20170900.CME_Eq | 2017-10-18 08:49:16 CTS T4 FIX | Requesting Open Orders for account: 460*. Request ID: 1540782 | 2017-10-18 08:49:17 HD Request # 4 | Downloading Intraday chart data for ES.20171200.CME_Eq to the file ES.20171200.CME_Eq.scid. Service: cts | 2017-10-18 08:49:21 HD Request # 4 | Download start date-time: 2017-10-18 08:47:59.000 | 2017-10-18 08:49:21 CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2017-10-18 08:49:21 CTS FIX Historical Data socket (16) | Creating socket. Using TLS 1.0. | 2017-10-18 08:49:21 CTS FIX Historical Data socket (16) | Connecting to IP: 69.44.110.227. | 2017-10-18 08:49:21 CTS FIX Historical Data: Sending the Logon message. | 2017-10-18 08:49:22 CTS FIX Historical Data: Connected to Historical data server. | 2017-10-18 08:49:22 CTS T4 FIX | Received unsolicited security definition for symbol 6E.20170900.CME_Fo. Making full security definition request for additional details. | 2017-10-18 08:49:22 CTS T4 FIX | Received Account Details collateral report for account: 46097 | 2017-10-18 08:49:22 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-10-18 08:49:22 CTS T4 FIX | Sending security definition request for symbol 6E.20170900.CME_Fo | 2017-10-18 08:49:23 CTS T4 FIX | No open orders for account 46097 | 2017-10-18 08:49:24 CTS T4 FIX | Received matching security definition for symbol ES.20171200.CME_Eq. Subscribing to data. | 2017-10-18 08:49:24 CTS T4 FIX | Received matching security definition for symbol ES.20171200.CME_Eq. Requesting historical data. | 2017-10-18 08:49:24 HD Request # 4 | Requesting historical Tick data for ES.20171200.CME_Eq from 2017-10-18 00:00:00 to 2017-10-18 00:00:00 (US Central Time). | 2017-10-18 08:49:24 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-10-18 08:49:24 Symbol Error - ES.20170900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-10-18 08:49:24 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-10-18 08:49:24 Symbol Error - 6E.20170900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-10-18 08:49:24 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-10-18 08:49:24 Contract specifications for ES.20171200.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-10-18 08:49:24 HD Request # 4 | Receiving Intraday data for ES.20171200.CME_Eq starting at 2017-10-17 17:00:00 | 2017-10-18 08:49:25 HD Request # 4 | Timestamp of first Intraday data file record written: 2017-10-18 08:47:59 | 2017-10-18 08:49:25 HD Request # 4 | Total records received: 55376 | 2017-10-18 08:49:25 HD Request # 4 | Requesting historical Tick data for ES.20171200.CME_Eq from 2017-10-19 00:00:00 to 2017-10-19 00:00:00 (US Central Time). | 2017-10-18 08:49:25 HD Request # 4 | Total records received: 55376 | 2017-10-18 08:49:25 HD Request # 4 | Requesting historical Tick data for ES.20171200.CME_Eq from 2017-10-20 00:00:00 to 2017-10-20 00:00:00 (US Central Time). | 2017-10-18 08:49:25 HD Request # 4 | Received 55376 records from 2017-10-17 17:00:00 to 2017-10-18 08:49:25 (15.8 hours) and wrote 1230 records for ES.20171200.CME_Eq | 2017-10-18 08:49:25 HD Request # 4 | Intraday download COMPLETE for ES.20171200.CME_Eq. Completion time: 4s. Unique request ID: 3 | 2017-10-18 08:49:25 Removed historical data download ID 3 | 2017-10-18 08:49:25 Real-time Intraday chart data file updates started for ES.20171200.CME_Eq | 2017-10-18 08:49:25 Intraday chart data file opened for ES.20171200.CME_Eq | 2017-10-18 08:49:25 HD Request # 5 | Downloading Intraday chart data for 6E.20171200.CME_Fo to the file 6E.20171200.CME_Fo.scid. Service: cts | 2017-10-18 08:49:25 HD Request # 5 | Download start date-time: 2017-10-18 08:47:58.000 | 2017-10-18 08:49:25 HD Request # 5 | Requesting historical Tick data for 6E.20171200.CME_Fo from 2017-10-18 00:00:00 to 2017-10-18 00:00:00 (US Central Time). | 2017-10-18 08:49:25 HD Request # 5 | Receiving Intraday data for 6E.20171200.CME_Fo starting at 2017-10-17 17:00:00 | 2017-10-18 08:49:25 HD Request # 5 | Timestamp of first Intraday data file record written: 2017-10-18 08:48:00 | 2017-10-18 08:49:25 HD Request # 5 | Total records received: 73664 | 2017-10-18 08:49:25 HD Request # 5 | Requesting historical Tick data for 6E.20171200.CME_Fo from 2017-10-19 00:00:00 to 2017-10-19 00:00:00 (US Central Time). | 2017-10-18 08:49:25 HD Request # 5 | Total records received: 73664 | 2017-10-18 08:49:25 HD Request # 5 | Requesting historical Tick data for 6E.20171200.CME_Fo from 2017-10-20 00:00:00 to 2017-10-20 00:00:00 (US Central Time). | 2017-10-18 08:49:25 HD Request # 5 | Received 73664 records from 2017-10-17 17:00:00 to 2017-10-18 08:49:25 (15.8 hours) and wrote 156 records for 6E.20171200.CME_Fo | 2017-10-18 08:49:26 HD Request # 5 | Intraday download COMPLETE for 6E.20171200.CME_Fo. Completion time: 0s. Unique request ID: 4 | 2017-10-18 08:49:26 Removed historical data download ID 4 | 2017-10-18 08:49:26 Real-time Intraday chart data file updates started for 6E.20171200.CME_Fo | 2017-10-18 08:49:26 Intraday chart data file opened for 6E.20171200.CME_Fo | 2017-10-18 08:49:26 Opened cached Intraday file: F:\SierraChart\Data\ES.20171200.CME_Eq.scid | 2017-10-18 08:49:26 Opened cached Intraday file: F:\SierraChart\Data\6E.20171200.CME_Fo.scid | 2017-10-18 08:49:26 CTS T4 FIX | Requesting historical Fills for account: 460*. Request ID: 1540785 | 2017-10-18 08:49:27 CTS T4 FIX | Received Account List collateral report. | 2017-10-18 08:49:27 CTS T4 FIX | Server provided no historical order fills for account 250395C5-931E-4E6C-9045-9D7B7F369BBA | 2017-10-18 08:49:27 CTS FIX Historical Data socket (16) | Socket gracefully closed by remote side. | 2017-10-18 08:49:57 CTS FIX Historical Data socket (16) | Adding bytes from final send buffer from buffered socket: 132 | 2017-10-18 08:49:57 CTS FIX Historical Data socket (16) | Initiating close of socket by core. | 2017-10-18 08:49:57 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2017-10-18 08:49:57 CTS FIX Historical Data socket (16) | Received socket Close event | 2017-10-18 08:49:57 CTS FIX Historical Data socket (16) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-18 08:49:57 CTS FIX Historical Data socket (16) | Closed. | 2017-10-18 08:49:57 CTS FIX Historical Data: Disconnected. | 2017-10-18 08:49:57 CTS FIX socket (15) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-18 08:50:30 * CTS FIX socket (15) | Socket gracefully closed by remote side. | 2017-10-18 08:50:30 CTS FIX socket (15) | Received socket Close event | 2017-10-18 08:50:30 CTS FIX socket (15) | Initiating close of socket by core. | 2017-10-18 08:50:30 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-10-18 08:50:30 CTS FIX socket (15) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-18 08:50:30 CTS FIX socket (15) | Closed. | 2017-10-18 08:50:30 Connection to the external service has been lost. | 2017-10-18 08:50:30 CTS T4 FIX | Disconnected. | 2017-10-18 08:50:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:50:30 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-18 08:50:33 CTS T4 FIX | Firm: Dorman | 2017-10-18 08:50:33 CTS FIX socket (18) | Creating socket. Using TLS 1.0. | 2017-10-18 08:50:33 CTS FIX socket (18) | Connecting to IP: 74.201.6.106. | 2017-10-18 08:50:33 CTS FIX: Sending the Logon message. | 2017-10-18 08:50:36 CTS FIX: Sent heartbeat to server. | 2017-10-18 08:51:06 CTS FIX socket (18) | Socket gracefully closed by remote side. | 2017-10-18 08:51:10 CTS FIX socket (18) | Received socket Close event | 2017-10-18 08:51:10 CTS FIX socket (18) | Initiating close of socket by core. | 2017-10-18 08:51:10 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-10-18 08:51:10 CTS FIX socket (18) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-18 08:51:10 CTS FIX socket (18) | Closed. | 2017-10-18 08:51:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-18 08:51:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:51:10 CTS T4 FIX | Disconnected. | 2017-10-18 08:51:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:51:10 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-18 08:51:13 CTS T4 FIX | Firm: Dorman | 2017-10-18 08:51:13 CTS FIX socket (19) | Creating socket. Using TLS 1.0. | 2017-10-18 08:51:13 CTS FIX socket (19) | Connecting to IP: 208.116.215.102. | 2017-10-18 08:51:13 CTS FIX socket (19) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-10-18 08:51:34 * CTS FIX socket (19) | Initiating close of socket by core. | 2017-10-18 08:51:34 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-10-18 08:51:34 CTS FIX socket (19) | Closed. | 2017-10-18 08:51:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-18 08:51:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:51:34 CTS T4 FIX | Disconnected. | 2017-10-18 08:51:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:51:34 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-18 08:51:37 CTS T4 FIX | Firm: Dorman | 2017-10-18 08:51:37 CTS FIX socket (20) | Creating socket. Using TLS 1.0. | 2017-10-18 08:51:39 CTS FIX socket (20) | Connecting to IP: 208.116.215.102. | 2017-10-18 08:51:39 CTS FIX socket (20) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-10-18 08:52:00 * CTS FIX socket (20) | Initiating close of socket by core. | 2017-10-18 08:52:00 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-10-18 08:52:00 CTS FIX socket (20) | Closed. | 2017-10-18 08:52:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-18 08:52:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:52:00 CTS T4 FIX | Disconnected. | 2017-10-18 08:52:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 08:52:00 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-18 08:52:03 CTS T4 FIX | Firm: Dorman | 2017-10-18 08:52:03 CTS FIX socket (21) | Creating socket. Using TLS 1.0. | 2017-10-18 08:52:04 CTS FIX socket (21) | Connecting to IP: 69.44.110.106. | 2017-10-18 08:52:04 CTS FIX: Sending the Logon message. | 2017-10-18 08:52:07 CTS T4 FIX | FIX version: 4.3.73.5 | 2017-10-18 08:52:17 CTS T4 FIX | Connected to data and trading server. | 2017-10-18 08:52:17 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-18 08:52:17 CTS T4 FIX | Starting real-time market data updates for: ES.20171200.CME_Eq. ID: 1 | 2017-10-18 08:52:17 CTS T4 FIX | Requesting security definition data for: ES.20171200.CME_Eq. ID: 1 | 2017-10-18 08:52:17 CTS T4 FIX | Using primary service for historical data for ES.20171200.CME_Eq | 2017-10-18 08:52:17 Intraday data recording state for symbol ES.20171200.CME_Eq is set to download 'Pending'. | 2017-10-18 08:52:17 Delaying start of download for ES.20171200.CME_Eq | 2017-10-18 08:52:17 CTS T4 FIX | Received Account List collateral report. | 2017-10-18 08:52:17 CTS T4 FIX | Subscribing to account: 460* | 2017-10-18 08:52:17 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-18 08:52:17 CTS T4 FIX | Starting real-time market data updates for: 6E.20171200.CME_Fo. ID: 2 | 2017-10-18 08:52:17 CTS T4 FIX | Requesting security definition data for: 6E.20171200.CME_Fo. ID: 2 | 2017-10-18 08:52:17 CTS T4 FIX | Using primary service for historical data for 6E.20171200.CME_Fo | 2017-10-18 08:52:17 Intraday data recording state for symbol 6E.20171200.CME_Fo is set to download 'Pending'. | 2017-10-18 08:52:17 Supported exchange: L_J (Euronext Index Futures) | 2017-10-18 08:52:17 Supported exchange: ICE_IC (ICE EU Futures) | 2017-10-18 08:52:17 Supported exchange: L_Y (Euronext Commodity Futures) | 2017-10-18 08:52:17 Supported exchange: CME_ELE (NYMEX Power Futures) | 2017-10-18 08:52:17 Supported exchange: SGX_COp (SGX Commodity Options) | 2017-10-18 08:52:17 Supported exchange: ICE_WOp (ICE Canada Options) | 2017-10-18 08:52:17 Supported exchange: L_YOp (Euronext Commodity Options) | 2017-10-18 08:52:17 Supported exchange: E_INXOp (Eurex Index Options) | 2017-10-18 08:52:17 Supported exchange: CME_FRE (NYMEX Freight Futures) | 2017-10-18 08:52:17 Supported exchange: CME_KOp (KCBT Options) | 2017-10-18 08:52:17 Supported exchange: CME_HoOp (CME Housing Options) | 2017-10-18 08:52:17 Supported exchange: E_FITOp (Eurex Interest Rate Options) | 2017-10-18 08:52:17 Supported exchange: ICE_ICOp (ICE EU Options) | 2017-10-18 08:52:17 Supported exchange: ICE_FOp (ICE EU Financial Options) | 2017-10-18 08:52:17 Supported exchange: ICE_CO (ICE US Commodity Futures) | 2017-10-18 08:52:17 Supported exchange: CME_COAL (NYMEX Coal Futures) | 2017-10-18 08:52:17 Supported exchange: CME_COp (CBOT Commodity Options) | 2017-10-18 08:52:17 Supported exchange: SGX_C (SGX Commodity Futures) | 2017-10-18 08:52:17 Supported exchange: CME_EqOp (CME Equity Options) | 2017-10-18 08:52:17 Supported exchange: E_VOL (Eurex Volatility Futures) | 2017-10-18 08:52:17 Supported exchange: CME_CL (NYMEX CrudeOil Futures) | 2017-10-18 08:52:17 Supported exchange: ICE_IN (ICE US Index Futures) | 2017-10-18 08:52:17 Supported exchange: CME_Fo (CME Foreign Exchange Futures) | 2017-10-18 08:52:17 Supported exchange: CME_Ho (CME Housing Futures) | 2017-10-18 08:52:17 Supported exchange: ICE_INOp (ICE US Index Options) | 2017-10-18 08:52:17 Supported exchange: CME_AgOp (CME Agricultural Options) | 2017-10-18 08:52:17 Supported exchange: CME_In (CME Interest Rate Futures) | 2017-10-18 08:52:17 Supported exchange: E_CUR (Eurex Currency Futures) | 2017-10-18 08:52:17 Supported exchange: E_FBDOp (Eurex Fixed Income Options) | 2017-10-18 08:52:17 Supported exchange: CME_CO (COMEX Futures) | 2017-10-18 08:52:17 Supported exchange: CME_Ag (CME Agricultural Futures) | 2017-10-18 08:52:17 Supported exchange: CME_EOp (CBOT Equity Options) | 2017-10-18 08:52:17 Supported exchange: CME_C (CBOT Commodity Futures) | 2017-10-18 08:52:17 Supported exchange: CME_F (CBOT Financial Futures) | 2017-10-18 08:52:17 Supported exchange: CME_E (CBOT Equity Futures) | 2017-10-18 08:52:17 Supported exchange: CME_K (KCBT Futures) | 2017-10-18 08:52:17 Supported exchange: CME_O (MGEX Futures) | 2017-10-18 08:52:17 Supported exchange: LME_PR (LME Precious Metal Futures) | 2017-10-18 08:52:17 Supported exchange: CME_FOp (CBOT Financial Options) | 2017-10-18 08:52:17 Supported exchange: ICE_MOp (ICE US Metals Options) | 2017-10-18 08:52:17 Supported exchange: E_FIXOp (E_FIXOp) | 2017-10-18 08:52:17 Supported exchange: E_INX (Eurex Index Futures) | 2017-10-18 08:52:17 Supported exchange: ICE_M (ICE US Metals Futures) | 2017-10-18 08:52:17 Supported exchange: CME_OOp (MGEX Options) | 2017-10-18 08:52:17 Supported exchange: CME_COALOp (NYMEX Coal Options) | 2017-10-18 08:52:17 Supported exchange: ICE_CU (ICE US Currency Futures) | 2017-10-18 08:52:17 Supported exchange: ICE_C (ICE EU Commodity Futures) | 2017-10-18 08:52:17 Supported exchange: CME_NG (NYMEX NatGas Futures) | 2017-10-18 08:52:17 Supported exchange: CME_CLOp (NYMEX CrudeOil Options) | 2017-10-18 08:52:17 Supported exchange: E_INT (Eurex Interest Rate Futures) | 2017-10-18 08:52:17 Supported exchange: ICE_F (ICE EU Financial Futures) | 2017-10-18 08:52:17 Supported exchange: CME_NYOp (NYMEX Options) | 2017-10-18 08:52:17 Supported exchange: CME_We (CME Weather Futures) | 2017-10-18 08:52:17 Supported exchange: CME_REFOp (NYMEX Refined Products Options) | 2017-10-18 08:52:17 Supported exchange: CME_PET (NYMEX NGL/Petrochemicals Futures) | 2017-10-18 08:52:17 Supported exchange: ICE_W (ICE Canada Futures) | 2017-10-18 08:52:17 Supported exchange: ICE_COOp (ICE US Commodity Options) | 2017-10-18 08:52:17 Supported exchange: E_CUROp (Eurex Currency Options) | 2017-10-18 08:52:17 Supported exchange: CME_PETOp (NYMEX NGL/Petrochemicals Options) | 2017-10-18 08:52:17 Supported exchange: E_BND (Eurex Fixed Income Futures) | 2017-10-18 08:52:17 Supported exchange: CME_COOp (COMEX Options) | 2017-10-18 08:52:17 Supported exchange: LME_ME (LME Metal Futures) | 2017-10-18 08:52:17 Supported exchange: LME_PL (LME Plastic Futures) | 2017-10-18 08:52:17 Supported exchange: ICE_COp (ICE EU Commodity Options) | 2017-10-18 08:52:17 Supported exchange: CME_InOp (CME Interest Rate Options) | 2017-10-18 08:52:17 Supported exchange: CME_FREOp (NYMEX Freight Options) | 2017-10-18 08:52:17 Supported exchange: CME_ELEOp (NYMEX Power Options) | 2017-10-18 08:52:17 Supported exchange: CME_Eq (CME Equity Futures) | 2017-10-18 08:52:17 Supported exchange: CBOE_CFE (CFE) | 2017-10-18 08:52:17 Supported exchange: CME_NGOp (NYMEX NatGas Options) | 2017-10-18 08:52:17 Supported exchange: CME_NY (NYMEX Futures) | 2017-10-18 08:52:17 Supported exchange: CME_FoOp (CME Foreign Exchange Options) | 2017-10-18 08:52:17 Supported exchange: CME_REF (NYMEX Refined Products Futures) | 2017-10-18 08:52:17 Supported exchange: LME_IN (LME Index Futures) | 2017-10-18 08:52:17 CTS T4 FIX | Sending security definition request for symbol 6E.20171200.CME_Fo | 2017-10-18 08:52:18 CTS T4 FIX | Received matching security definition for symbol 6E.20171200.CME_Fo. Subscribing to data. | 2017-10-18 08:52:18 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-10-18 08:52:18 Contract specifications for 6E.20171200.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-10-18 08:52:19 CTS T4 FIX | Sending security definition request for symbol ES.20171200.CME_Eq | 2017-10-18 08:52:20 CTS T4 FIX | Received unsolicited security definition for symbol ES.20171200.CME_Eq. Making full security definition request for additional details. | 2017-10-18 08:52:21 CTS T4 FIX | Received unsolicited security definition for symbol ES.20170900.CME_Eq. Making full security definition request for additional details. | 2017-10-18 08:52:21 CTS T4 FIX | Sending security definition request for symbol ES.20170900.CME_Eq | 2017-10-18 08:52:21 CTS T4 FIX | Received unsolicited security definition for symbol 6E.20170900.CME_Fo. Making full security definition request for additional details. | 2017-10-18 08:52:21 CTS T4 FIX | Received Account Details collateral report for account: 46097 | 2017-10-18 08:52:21 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-10-18 08:52:21 CTS T4 FIX | Received matching security definition for symbol ES.20171200.CME_Eq. Subscribing to data. | 2017-10-18 08:52:21 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-10-18 08:52:21 Symbol Error - ES.20170900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-10-18 08:52:21 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-10-18 08:52:21 Contract specifications for ES.20171200.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-10-18 08:52:21 CTS T4 FIX | Requesting Open Orders for account: 460*. Request ID: 1540795 | 2017-10-18 08:52:22 CTS T4 FIX | No open orders for account 46097 | 2017-10-18 08:52:22 HD Request # 6 | Downloading Intraday chart data for ES.20171200.CME_Eq to the file ES.20171200.CME_Eq.scid. Service: cts | 2017-10-18 08:52:22 HD Request # 6 | Download start date-time: 2017-10-18 08:49:39.000 | 2017-10-18 08:52:22 CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2017-10-18 08:52:22 CTS T4 FIX | Sending security definition request for symbol 6E.20170900.CME_Fo | 2017-10-18 08:52:23 Symbol Error - 6E.20170900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-10-18 08:52:23 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-10-18 08:52:23 CTS FIX Historical Data socket (23) | Creating socket. Using TLS 1.0. | 2017-10-18 08:52:23 CTS FIX Historical Data socket (23) | Connecting to IP: 69.44.110.227. | 2017-10-18 08:52:23 CTS FIX Historical Data: Sending the Logon message. | 2017-10-18 08:52:26 CTS FIX Historical Data: Connected to Historical data server. | 2017-10-18 08:52:26 HD Request # 6 | Requesting historical Tick data for ES.20171200.CME_Eq from 2017-10-18 00:00:00 to 2017-10-18 00:00:00 (US Central Time). | 2017-10-18 08:52:26 CTS T4 FIX | Requesting historical Fills for account: 460*. Request ID: 1540796 | 2017-10-18 08:52:32 CTS T4 FIX | Received Account List collateral report. | 2017-10-18 08:52:32 CTS T4 FIX | Server provided no historical order fills for account 250395C5-931E-4E6C-9045-9D7B7F369BBA | 2017-10-18 08:52:32 HD Request # 6 | Receiving Intraday data for ES.20171200.CME_Eq starting at 2017-10-17 17:00:00 | 2017-10-18 08:52:46 HD Request # 6 | Timestamp of first Intraday data file record written: 2017-10-18 08:49:40 | 2017-10-18 08:52:46 HD Request # 6 | Total records received: 57196 | 2017-10-18 08:52:46 HD Request # 6 | Requesting historical Tick data for ES.20171200.CME_Eq from 2017-10-19 00:00:00 to 2017-10-19 00:00:00 (US Central Time). | 2017-10-18 08:52:46 HD Request # 6 | Total records received: 57196 | 2017-10-18 08:52:47 HD Request # 6 | Requesting historical Tick data for ES.20171200.CME_Eq from 2017-10-20 00:00:00 to 2017-10-20 00:00:00 (US Central Time). | 2017-10-18 08:52:47 HD Request # 6 | Received 57196 records from 2017-10-17 17:00:00 to 2017-10-18 08:52:27 (15.9 hours) and wrote 1796 records for ES.20171200.CME_Eq | 2017-10-18 08:52:47 Added 53 Time and Sales records to Intraday data file for ES.20171200.CME_Eq after download. | 2017-10-18 08:52:47 HD Request # 6 | Intraday download COMPLETE for ES.20171200.CME_Eq. Completion time: 25s. Unique request ID: 5 | 2017-10-18 08:52:47 Removed historical data download ID 5 | 2017-10-18 08:52:47 Real-time Intraday chart data file updates started for ES.20171200.CME_Eq | 2017-10-18 08:52:47 Intraday chart data file opened for ES.20171200.CME_Eq | 2017-10-18 08:52:47 HD Request # 7 | Downloading Intraday chart data for 6E.20171200.CME_Fo to the file 6E.20171200.CME_Fo.scid. Service: cts | 2017-10-18 08:52:47 HD Request # 7 | Download start date-time: 2017-10-18 08:49:39.000 | 2017-10-18 08:52:47 HD Request # 7 | Requesting historical Tick data for 6E.20171200.CME_Fo from 2017-10-18 00:00:00 to 2017-10-18 00:00:00 (US Central Time). | 2017-10-18 08:52:47 Opened cached Intraday file: F:\SierraChart\Data\ES.20171200.CME_Eq.scid | 2017-10-18 08:52:49 HD Request # 7 | Receiving Intraday data for 6E.20171200.CME_Fo starting at 2017-10-17 17:00:00 | 2017-10-18 08:52:51 HD Request # 7 | Timestamp of first Intraday data file record written: 2017-10-18 08:49:43 | 2017-10-18 08:52:51 HD Request # 7 | Total records received: 73971 | 2017-10-18 08:52:51 HD Request # 7 | Requesting historical Tick data for 6E.20171200.CME_Fo from 2017-10-19 00:00:00 to 2017-10-19 00:00:00 (US Central Time). | 2017-10-18 08:52:51 HD Request # 7 | Total records received: 73971 | 2017-10-18 08:52:51 HD Request # 7 | Requesting historical Tick data for 6E.20171200.CME_Fo from 2017-10-20 00:00:00 to 2017-10-20 00:00:00 (US Central Time). | 2017-10-18 08:52:51 HD Request # 7 | Received 73971 records from 2017-10-17 17:00:00 to 2017-10-18 08:52:41 (15.9 hours) and wrote 280 records for 6E.20171200.CME_Fo | 2017-10-18 08:52:51 Added 2 Time and Sales records to Intraday data file for 6E.20171200.CME_Fo after download. | 2017-10-18 08:52:51 HD Request # 7 | Intraday download COMPLETE for 6E.20171200.CME_Fo. Completion time: 4s. Unique request ID: 6 | 2017-10-18 08:52:51 Removed historical data download ID 6 | 2017-10-18 08:52:51 Real-time Intraday chart data file updates started for 6E.20171200.CME_Fo | 2017-10-18 08:52:51 Intraday chart data file opened for 6E.20171200.CME_Fo | 2017-10-18 08:52:51 Opened cached Intraday file: F:\SierraChart\Data\6E.20171200.CME_Fo.scid | 2017-10-18 08:52:59 CTS FIX Historical Data socket (23) | Socket gracefully closed by remote side. | 2017-10-18 08:53:52 CTS FIX Historical Data socket (23) | Received socket Close event | 2017-10-18 08:53:52 CTS FIX Historical Data socket (23) | Initiating close of socket by core. | 2017-10-18 08:53:52 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2017-10-18 08:53:52 CTS FIX Historical Data socket (23) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-18 08:53:52 CTS FIX Historical Data socket (23) | Closed. | 2017-10-18 08:53:52 CTS FIX Historical Data: Disconnected. | 2017-10-18 08:53:52 CTS FIX socket (21) | Socket gracefully closed by remote side. | 2017-10-18 11:12:37 CTS FIX socket (21) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-18 11:12:37 * CTS FIX socket (21) | Initiating close of socket by core. | 2017-10-18 11:12:37 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-10-18 11:12:37 CTS FIX socket (21) | Received socket Close event | 2017-10-18 11:12:37 CTS FIX socket (21) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-18 11:12:37 CTS FIX socket (21) | Closed. | 2017-10-18 11:12:37 Connection to the external service has been lost. | 2017-10-18 11:12:37 CTS T4 FIX | Disconnected. | 2017-10-18 11:12:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 11:12:37 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-18 11:12:40 CTS T4 FIX | Firm: Dorman | 2017-10-18 11:12:40 Error getting address info for fix.t4login.com. Windows error code 11001: No such host is known. | 2017-10-18 11:12:55 * CTS FIX socket (71) | Initiating close of socket by core. | 2017-10-18 11:12:55 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-10-18 11:12:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-18 11:12:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 11:12:55 CTS T4 FIX | Disconnected. | 2017-10-18 11:12:55 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 11:12:55 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-18 11:12:58 CTS T4 FIX | Firm: Dorman | 2017-10-18 11:12:58 CTS FIX socket (72) | Creating socket. Using TLS 1.0. | 2017-10-18 11:13:07 CTS FIX socket (72) | Connecting to IP: 74.201.6.106. | 2017-10-18 11:13:07 CTS FIX: Sending the Logon message. | 2017-10-18 11:13:10 CTS T4 FIX | FIX version: 4.3.73.5 | 2017-10-18 11:13:22 CTS T4 FIX | Connected to data and trading server. | 2017-10-18 11:13:22 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-18 11:13:22 CTS T4 FIX | Starting real-time market data updates for: ES.20171200.CME_Eq. ID: 1 | 2017-10-18 11:13:22 CTS T4 FIX | Requesting security definition data for: ES.20171200.CME_Eq. ID: 1 | 2017-10-18 11:13:22 CTS T4 FIX | Using primary service for historical data for ES.20171200.CME_Eq | 2017-10-18 11:13:22 Intraday data recording state for symbol ES.20171200.CME_Eq is set to download 'Pending'. | 2017-10-18 11:13:22 Delaying start of download for ES.20171200.CME_Eq | 2017-10-18 11:13:22 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-18 11:13:22 CTS T4 FIX | Starting real-time market data updates for: 6E.20171200.CME_Fo. ID: 2 | 2017-10-18 11:13:22 CTS T4 FIX | Requesting security definition data for: 6E.20171200.CME_Fo. ID: 2 | 2017-10-18 11:13:22 CTS T4 FIX | Using primary service for historical data for 6E.20171200.CME_Fo | 2017-10-18 11:13:22 Intraday data recording state for symbol 6E.20171200.CME_Fo is set to download 'Pending'. | 2017-10-18 11:13:22 CTS T4 FIX | Sending security definition request for symbol 6E.20171200.CME_Fo | 2017-10-18 11:13:23 CTS T4 FIX | Sending security definition request for symbol ES.20171200.CME_Eq | 2017-10-18 11:13:25 HD Request # 8 | Downloading Intraday chart data for ES.20171200.CME_Eq to the file ES.20171200.CME_Eq.scid. Service: cts | 2017-10-18 11:13:31 HD Request # 8 | Download start date-time: 2017-10-18 11:12:17.000 | 2017-10-18 11:13:31 CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2017-10-18 11:13:31 CTS T4 FIX | Received Account List collateral report. | 2017-10-18 11:13:43 CTS T4 FIX | Subscribing to account: 460* | 2017-10-18 11:13:43 Supported exchange: L_J (Euronext Index Futures) | 2017-10-18 11:13:43 Supported exchange: ICE_IC (ICE EU Futures) | 2017-10-18 11:13:43 Supported exchange: L_Y (Euronext Commodity Futures) | 2017-10-18 11:13:43 Supported exchange: CME_ELE (NYMEX Power Futures) | 2017-10-18 11:13:43 Supported exchange: SGX_COp (SGX Commodity Options) | 2017-10-18 11:13:43 Supported exchange: ICE_WOp (ICE Canada Options) | 2017-10-18 11:13:43 Supported exchange: L_YOp (Euronext Commodity Options) | 2017-10-18 11:13:43 Supported exchange: E_INXOp (Eurex Index Options) | 2017-10-18 11:13:43 Supported exchange: CME_FRE (NYMEX Freight Futures) | 2017-10-18 11:13:43 Supported exchange: CME_KOp (KCBT Options) | 2017-10-18 11:13:43 Supported exchange: CME_HoOp (CME Housing Options) | 2017-10-18 11:13:43 Supported exchange: E_FITOp (Eurex Interest Rate Options) | 2017-10-18 11:13:43 Supported exchange: ICE_ICOp (ICE EU Options) | 2017-10-18 11:13:43 Supported exchange: ICE_FOp (ICE EU Financial Options) | 2017-10-18 11:13:43 Supported exchange: ICE_CO (ICE US Commodity Futures) | 2017-10-18 11:13:43 Supported exchange: CME_COAL (NYMEX Coal Futures) | 2017-10-18 11:13:43 Supported exchange: CME_COp (CBOT Commodity Options) | 2017-10-18 11:13:43 Supported exchange: SGX_C (SGX Commodity Futures) | 2017-10-18 11:13:43 Supported exchange: CME_EqOp (CME Equity Options) | 2017-10-18 11:13:43 Supported exchange: E_VOL (Eurex Volatility Futures) | 2017-10-18 11:13:43 Supported exchange: CME_CL (NYMEX CrudeOil Futures) | 2017-10-18 11:13:43 Supported exchange: ICE_IN (ICE US Index Futures) | 2017-10-18 11:13:43 Supported exchange: CME_Fo (CME Foreign Exchange Futures) | 2017-10-18 11:13:43 Supported exchange: CME_Ho (CME Housing Futures) | 2017-10-18 11:13:43 Supported exchange: ICE_INOp (ICE US Index Options) | 2017-10-18 11:13:43 Supported exchange: CME_AgOp (CME Agricultural Options) | 2017-10-18 11:13:43 Supported exchange: CME_In (CME Interest Rate Futures) | 2017-10-18 11:13:43 Supported exchange: E_CUR (Eurex Currency Futures) | 2017-10-18 11:13:43 Supported exchange: E_FBDOp (Eurex Fixed Income Options) | 2017-10-18 11:13:43 Supported exchange: CME_CO (COMEX Futures) | 2017-10-18 11:13:43 Supported exchange: CME_Ag (CME Agricultural Futures) | 2017-10-18 11:13:43 Supported exchange: CME_EOp (CBOT Equity Options) | 2017-10-18 11:13:43 Supported exchange: CME_C (CBOT Commodity Futures) | 2017-10-18 11:13:43 Supported exchange: CME_F (CBOT Financial Futures) | 2017-10-18 11:13:43 Supported exchange: CME_E (CBOT Equity Futures) | 2017-10-18 11:13:43 Supported exchange: CME_K (KCBT Futures) | 2017-10-18 11:13:43 Supported exchange: CME_O (MGEX Futures) | 2017-10-18 11:13:43 Supported exchange: LME_PR (LME Precious Metal Futures) | 2017-10-18 11:13:43 Supported exchange: CME_FOp (CBOT Financial Options) | 2017-10-18 11:13:43 Supported exchange: ICE_MOp (ICE US Metals Options) | 2017-10-18 11:13:43 Supported exchange: E_FIXOp (E_FIXOp) | 2017-10-18 11:13:43 Supported exchange: E_INX (Eurex Index Futures) | 2017-10-18 11:13:43 Supported exchange: ICE_M (ICE US Metals Futures) | 2017-10-18 11:13:43 Supported exchange: CME_OOp (MGEX Options) | 2017-10-18 11:13:43 Supported exchange: CME_COALOp (NYMEX Coal Options) | 2017-10-18 11:13:43 Supported exchange: ICE_CU (ICE US Currency Futures) | 2017-10-18 11:13:43 Supported exchange: ICE_C (ICE EU Commodity Futures) | 2017-10-18 11:13:43 Supported exchange: CME_NG (NYMEX NatGas Futures) | 2017-10-18 11:13:43 Supported exchange: CME_CLOp (NYMEX CrudeOil Options) | 2017-10-18 11:13:43 Supported exchange: E_INT (Eurex Interest Rate Futures) | 2017-10-18 11:13:43 Supported exchange: ICE_F (ICE EU Financial Futures) | 2017-10-18 11:13:43 Supported exchange: CME_NYOp (NYMEX Options) | 2017-10-18 11:13:43 Supported exchange: CME_We (CME Weather Futures) | 2017-10-18 11:13:43 Supported exchange: CME_REFOp (NYMEX Refined Products Options) | 2017-10-18 11:13:43 Supported exchange: CME_PET (NYMEX NGL/Petrochemicals Futures) | 2017-10-18 11:13:43 Supported exchange: ICE_W (ICE Canada Futures) | 2017-10-18 11:13:43 Supported exchange: ICE_COOp (ICE US Commodity Options) | 2017-10-18 11:13:43 Supported exchange: E_CUROp (Eurex Currency Options) | 2017-10-18 11:13:43 Supported exchange: CME_PETOp (NYMEX NGL/Petrochemicals Options) | 2017-10-18 11:13:43 Supported exchange: E_BND (Eurex Fixed Income Futures) | 2017-10-18 11:13:43 Supported exchange: CME_COOp (COMEX Options) | 2017-10-18 11:13:43 Supported exchange: LME_ME (LME Metal Futures) | 2017-10-18 11:13:43 Supported exchange: LME_PL (LME Plastic Futures) | 2017-10-18 11:13:43 Supported exchange: ICE_COp (ICE EU Commodity Options) | 2017-10-18 11:13:43 Supported exchange: CME_InOp (CME Interest Rate Options) | 2017-10-18 11:13:43 Supported exchange: CME_FREOp (NYMEX Freight Options) | 2017-10-18 11:13:43 Supported exchange: CME_ELEOp (NYMEX Power Options) | 2017-10-18 11:13:43 Supported exchange: CME_Eq (CME Equity Futures) | 2017-10-18 11:13:43 Supported exchange: CBOE_CFE (CFE) | 2017-10-18 11:13:43 Supported exchange: CME_NGOp (NYMEX NatGas Options) | 2017-10-18 11:13:43 Supported exchange: CME_NY (NYMEX Futures) | 2017-10-18 11:13:43 Supported exchange: CME_FoOp (CME Foreign Exchange Options) | 2017-10-18 11:13:43 Supported exchange: CME_REF (NYMEX Refined Products Futures) | 2017-10-18 11:13:43 Supported exchange: LME_IN (LME Index Futures) | 2017-10-18 11:13:43 CTS T4 FIX | Received matching security definition for symbol 6E.20171200.CME_Fo. Subscribing to data. | 2017-10-18 11:13:43 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-10-18 11:13:43 CTS T4 FIX | Received matching security definition for symbol ES.20171200.CME_Eq. Subscribing to data. | 2017-10-18 11:13:43 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-10-18 11:13:43 Contract specifications for 6E.20171200.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-10-18 11:13:43 Contract specifications for ES.20171200.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-10-18 11:13:43 Error getting address info for fix-chart.t4login.com. Windows error code 11001: No such host is known. | 2017-10-18 11:13:43 * CTS FIX Historical Data socket (74) | Initiating close of socket by core. | 2017-10-18 11:13:43 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2017-10-18 11:13:43 CTS FIX Historical Data: Disconnected. | 2017-10-18 11:13:43 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES.20171200.CME_Eq | 2017-10-18 11:13:43 HD Request # 9 | Downloading Intraday chart data for ES.20171200.CME_Eq to the file ES.20171200.CME_Eq.scid. Service: cts | 2017-10-18 11:13:43 HD Request # 9 | Download start date-time: 2017-10-18 11:12:17.000 | 2017-10-18 11:13:43 CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2017-10-18 11:13:43 CTS FIX Historical Data socket (75) | Creating socket. Using TLS 1.0. | 2017-10-18 11:13:43 CTS FIX Historical Data socket (75) | Connecting to IP: 208.116.215.116. | 2017-10-18 11:13:43 CTS FIX socket (72) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-10-18 11:13:44 CTS FIX socket (72) | Initiating close of socket by core. | 2017-10-18 11:13:44 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2017-10-18 11:13:44 CTS FIX socket (72) | Shutdown started. Waiting for graceful close. | 2017-10-18 11:13:44 Connection to the external service has been lost. | 2017-10-18 11:13:44 CTS FIX socket (72) | Received socket Close event | 2017-10-18 11:13:44 CTS FIX socket (72) | Closed. | 2017-10-18 11:13:44 Canceling historical data download request for 6E.20171200.CME_Fo Intraday data. | 2017-10-18 11:13:44 Removed historical data download ID 8 | 2017-10-18 11:13:44 HD Request # 9 | Download canceled. | 2017-10-18 11:13:44 HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES.20171200.CME_Eq | 2017-10-18 11:13:44 HD Request # 9 | Intraday download COMPLETE for ES.20171200.CME_Eq. Completion time: 0s. Unique request ID: 7 | 2017-10-18 11:13:44 Removed historical data download ID 7 | 2017-10-18 11:13:44 CTS FIX Historical Data: DisconnectFIX called. | 2017-10-18 11:13:44 CTS FIX Historical Data socket (75) | Initiating close of socket by core. | 2017-10-18 11:13:44 CTS FIX Historical Data: Disconnected. | 2017-10-18 11:13:44 CTS FIX Historical Data socket (75) | Closed. | 2017-10-18 11:13:44 CTS T4 FIX | Disconnected. | 2017-10-18 11:13:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-18 11:13:44 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2017-10-18 11:13:47 CTS T4 FIX | Firm: Dorman | 2017-10-18 11:13:47 CTS FIX socket (76) | Creating socket. Using TLS 1.0. | 2017-10-18 11:13:47 CTS FIX socket (76) | Connecting to IP: 69.44.110.106. | 2017-10-18 11:13:47 CTS FIX: Sending the Logon message. | 2017-10-18 11:13:47 CTS T4 FIX | FIX version: 4.3.73.5 | 2017-10-18 11:13:47 CTS T4 FIX | Connected to data and trading server. | 2017-10-18 11:13:47 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES.######00.CME_Eq pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-18 11:13:47 CTS T4 FIX | Starting real-time market data updates for: ES.20171200.CME_Eq. ID: 1 | 2017-10-18 11:13:47 CTS T4 FIX | Requesting security definition data for: ES.20171200.CME_Eq. ID: 1 | 2017-10-18 11:13:47 CTS T4 FIX | Using primary service for historical data for ES.20171200.CME_Eq | 2017-10-18 11:13:47 Intraday data recording state for symbol ES.20171200.CME_Eq is set to download 'Pending'. | 2017-10-18 11:13:47 Delaying start of download for ES.20171200.CME_Eq | 2017-10-18 11:13:47 CTS T4 FIX | Received Account List collateral report. | 2017-10-18 11:13:47 CTS T4 FIX | Subscribing to account: 460* | 2017-10-18 11:13:47 'Allow Support for Sierra Chart Data Feeds' is disabled. The 6E.######00.CME_Fo pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-18 11:13:47 CTS T4 FIX | Starting real-time market data updates for: 6E.20171200.CME_Fo. ID: 2 | 2017-10-18 11:13:47 CTS T4 FIX | Requesting security definition data for: 6E.20171200.CME_Fo. ID: 2 | 2017-10-18 11:13:47 CTS T4 FIX | Using primary service for historical data for 6E.20171200.CME_Fo | 2017-10-18 11:13:47 Intraday data recording state for symbol 6E.20171200.CME_Fo is set to download 'Pending'. | 2017-10-18 11:13:47 Supported exchange: L_J (Euronext Index Futures) | 2017-10-18 11:13:47 Supported exchange: ICE_IC (ICE EU Futures) | 2017-10-18 11:13:47 Supported exchange: L_Y (Euronext Commodity Futures) | 2017-10-18 11:13:47 Supported exchange: CME_ELE (NYMEX Power Futures) | 2017-10-18 11:13:47 Supported exchange: SGX_COp (SGX Commodity Options) | 2017-10-18 11:13:47 Supported exchange: ICE_WOp (ICE Canada Options) | 2017-10-18 11:13:47 Supported exchange: L_YOp (Euronext Commodity Options) | 2017-10-18 11:13:47 Supported exchange: E_INXOp (Eurex Index Options) | 2017-10-18 11:13:47 Supported exchange: CME_FRE (NYMEX Freight Futures) | 2017-10-18 11:13:47 Supported exchange: CME_KOp (KCBT Options) | 2017-10-18 11:13:47 Supported exchange: CME_HoOp (CME Housing Options) | 2017-10-18 11:13:47 Supported exchange: E_FITOp (Eurex Interest Rate Options) | 2017-10-18 11:13:47 Supported exchange: ICE_ICOp (ICE EU Options) | 2017-10-18 11:13:47 Supported exchange: ICE_FOp (ICE EU Financial Options) | 2017-10-18 11:13:47 Supported exchange: ICE_CO (ICE US Commodity Futures) | 2017-10-18 11:13:47 Supported exchange: CME_COAL (NYMEX Coal Futures) | 2017-10-18 11:13:47 Supported exchange: CME_COp (CBOT Commodity Options) | 2017-10-18 11:13:47 Supported exchange: SGX_C (SGX Commodity Futures) | 2017-10-18 11:13:47 Supported exchange: CME_EqOp (CME Equity Options) | 2017-10-18 11:13:47 Supported exchange: E_VOL (Eurex Volatility Futures) | 2017-10-18 11:13:47 Supported exchange: CME_CL (NYMEX CrudeOil Futures) | 2017-10-18 11:13:47 Supported exchange: ICE_IN (ICE US Index Futures) | 2017-10-18 11:13:47 Supported exchange: CME_Fo (CME Foreign Exchange Futures) | 2017-10-18 11:13:47 Supported exchange: CME_Ho (CME Housing Futures) | 2017-10-18 11:13:47 Supported exchange: ICE_INOp (ICE US Index Options) | 2017-10-18 11:13:47 Supported exchange: CME_AgOp (CME Agricultural Options) | 2017-10-18 11:13:47 Supported exchange: CME_In (CME Interest Rate Futures) | 2017-10-18 11:13:47 Supported exchange: E_CUR (Eurex Currency Futures) | 2017-10-18 11:13:47 Supported exchange: E_FBDOp (Eurex Fixed Income Options) | 2017-10-18 11:13:47 Supported exchange: CME_CO (COMEX Futures) | 2017-10-18 11:13:47 Supported exchange: CME_Ag (CME Agricultural Futures) | 2017-10-18 11:13:47 Supported exchange: CME_EOp (CBOT Equity Options) | 2017-10-18 11:13:47 Supported exchange: CME_C (CBOT Commodity Futures) | 2017-10-18 11:13:47 Supported exchange: CME_F (CBOT Financial Futures) | 2017-10-18 11:13:47 Supported exchange: CME_E (CBOT Equity Futures) | 2017-10-18 11:13:47 Supported exchange: CME_K (KCBT Futures) | 2017-10-18 11:13:47 Supported exchange: CME_O (MGEX Futures) | 2017-10-18 11:13:47 Supported exchange: LME_PR (LME Precious Metal Futures) | 2017-10-18 11:13:47 Supported exchange: CME_FOp (CBOT Financial Options) | 2017-10-18 11:13:47 Supported exchange: ICE_MOp (ICE US Metals Options) | 2017-10-18 11:13:47 Supported exchange: E_FIXOp (E_FIXOp) | 2017-10-18 11:13:47 Supported exchange: E_INX (Eurex Index Futures) | 2017-10-18 11:13:47 Supported exchange: ICE_M (ICE US Metals Futures) | 2017-10-18 11:13:47 Supported exchange: CME_OOp (MGEX Options) | 2017-10-18 11:13:47 Supported exchange: CME_COALOp (NYMEX Coal Options) | 2017-10-18 11:13:47 Supported exchange: ICE_CU (ICE US Currency Futures) | 2017-10-18 11:13:47 Supported exchange: ICE_C (ICE EU Commodity Futures) | 2017-10-18 11:13:47 Supported exchange: CME_NG (NYMEX NatGas Futures) | 2017-10-18 11:13:47 Supported exchange: CME_CLOp (NYMEX CrudeOil Options) | 2017-10-18 11:13:47 Supported exchange: E_INT (Eurex Interest Rate Futures) | 2017-10-18 11:13:47 Supported exchange: ICE_F (ICE EU Financial Futures) | 2017-10-18 11:13:47 Supported exchange: CME_NYOp (NYMEX Options) | 2017-10-18 11:13:47 Supported exchange: CME_We (CME Weather Futures) | 2017-10-18 11:13:47 Supported exchange: CME_REFOp (NYMEX Refined Products Options) | 2017-10-18 11:13:47 Supported exchange: CME_PET (NYMEX NGL/Petrochemicals Futures) | 2017-10-18 11:13:47 Supported exchange: ICE_W (ICE Canada Futures) | 2017-10-18 11:13:47 Supported exchange: ICE_COOp (ICE US Commodity Options) | 2017-10-18 11:13:47 Supported exchange: E_CUROp (Eurex Currency Options) | 2017-10-18 11:13:47 Supported exchange: CME_PETOp (NYMEX NGL/Petrochemicals Options) | 2017-10-18 11:13:47 Supported exchange: E_BND (Eurex Fixed Income Futures) | 2017-10-18 11:13:47 Supported exchange: CME_COOp (COMEX Options) | 2017-10-18 11:13:47 Supported exchange: LME_ME (LME Metal Futures) | 2017-10-18 11:13:47 Supported exchange: LME_PL (LME Plastic Futures) | 2017-10-18 11:13:47 Supported exchange: ICE_COp (ICE EU Commodity Options) | 2017-10-18 11:13:47 Supported exchange: CME_InOp (CME Interest Rate Options) | 2017-10-18 11:13:47 Supported exchange: CME_FREOp (NYMEX Freight Options) | 2017-10-18 11:13:47 Supported exchange: CME_ELEOp (NYMEX Power Options) | 2017-10-18 11:13:47 Supported exchange: CME_Eq (CME Equity Futures) | 2017-10-18 11:13:47 Supported exchange: CBOE_CFE (CFE) | 2017-10-18 11:13:47 Supported exchange: CME_NGOp (NYMEX NatGas Options) | 2017-10-18 11:13:47 Supported exchange: CME_NY (NYMEX Futures) | 2017-10-18 11:13:47 Supported exchange: CME_FoOp (CME Foreign Exchange Options) | 2017-10-18 11:13:47 Supported exchange: CME_REF (NYMEX Refined Products Futures) | 2017-10-18 11:13:47 Supported exchange: LME_IN (LME Index Futures) | 2017-10-18 11:13:47 CTS T4 FIX | Sending security definition request for symbol 6E.20171200.CME_Fo | 2017-10-18 11:13:48 CTS T4 FIX | Received matching security definition for symbol 6E.20171200.CME_Fo. Subscribing to data. | 2017-10-18 11:13:48 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2017-10-18 11:13:48 Contract specifications for 6E.20171200.CME_Fo. Multiplier: 0.1. Tick Size: 0.5. Value Format: 1. Currency Value per Tick: 6.25 | 2017-10-18 11:13:48 CTS T4 FIX | Received unsolicited security definition for symbol ES.20171200.CME_Eq. Making full security definition request for additional details. | 2017-10-18 11:13:49 CTS T4 FIX | Received unsolicited security definition for symbol ES.20170900.CME_Eq. Making full security definition request for additional details. | 2017-10-18 11:13:49 CTS T4 FIX | Received unsolicited security definition for symbol 6E.20170900.CME_Fo. Making full security definition request for additional details. | 2017-10-18 11:13:49 CTS T4 FIX | Received Account Details collateral report for account: 46097 | 2017-10-18 11:13:49 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2017-10-18 11:13:49 CTS T4 FIX | Sending security definition request for symbol 6E.20170900.CME_Fo | 2017-10-18 11:13:50 Symbol Error - 6E.20170900.CME_Fo is unknown, unavailable, or improperly formatted. Security definition not found | 2017-10-18 11:13:50 CTS T4 FIX | Received 0 security definitions for underlying symbol 6E | 2017-10-18 11:13:50 CTS T4 FIX | Sending security definition request for symbol ES.20170900.CME_Eq | 2017-10-18 11:13:51 Symbol Error - ES.20170900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2017-10-18 11:13:51 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2017-10-18 11:13:51 CTS T4 FIX | Requesting Open Orders for account: 460*. Request ID: 1540812 | 2017-10-18 11:13:52 CTS T4 FIX | No open orders for account 46097 | 2017-10-18 11:13:52 CTS T4 FIX | Sending security definition request for symbol ES.20171200.CME_Eq | 2017-10-18 11:13:52 CTS T4 FIX | Received matching security definition for symbol ES.20171200.CME_Eq. Subscribing to data. | 2017-10-18 11:13:53 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2017-10-18 11:13:53 Contract specifications for ES.20171200.CME_Eq. Multiplier: 0.01. Tick Size: 0.25. Value Format: 2. Currency Value per Tick: 12.5 | 2017-10-18 11:13:53 HD Request # 10 | Downloading Intraday chart data for ES.20171200.CME_Eq to the file ES.20171200.CME_Eq.scid. Service: cts | 2017-10-18 11:13:53 HD Request # 10 | Download start date-time: 2017-10-18 11:12:17.000 | 2017-10-18 11:13:53 CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2017-10-18 11:13:53 CTS FIX Historical Data socket (77) | Creating socket. Using TLS 1.0. | 2017-10-18 11:13:53 CTS FIX Historical Data socket (77) | Connecting to IP: 208.116.215.116. | 2017-10-18 11:13:53 CTS T4 FIX | Requesting historical Fills for account: 460*. Request ID: 1540814 | 2017-10-18 11:14:03 CTS T4 FIX | Received Account List collateral report. | 2017-10-18 11:14:03 CTS T4 FIX | Server provided no historical order fills for account 250395C5-931E-4E6C-9045-9D7B7F369BBA | 2017-10-18 11:14:03 CTS FIX Historical Data socket (77) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-10-18 11:14:15 * CTS FIX Historical Data socket (77) | Initiating close of socket by core. | 2017-10-18 11:14:15 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2017-10-18 11:14:15 CTS FIX Historical Data socket (77) | Closed. | 2017-10-18 11:14:15 CTS FIX Historical Data: Disconnected. | 2017-10-18 11:14:15 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES.20171200.CME_Eq | 2017-10-18 11:14:15 HD Request # 11 | Downloading Intraday chart data for ES.20171200.CME_Eq to the file ES.20171200.CME_Eq.scid. Service: cts | 2017-10-18 11:14:15 HD Request # 11 | Download start date-time: 2017-10-18 11:12:17.000 | 2017-10-18 11:14:15 CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2017-10-18 11:14:15 CTS FIX Historical Data socket (78) | Creating socket. Using TLS 1.0. | 2017-10-18 11:14:15 CTS FIX Historical Data socket (78) | Connecting to IP: 69.44.110.227. | 2017-10-18 11:14:15 CTS FIX Historical Data: Sending the Logon message. | 2017-10-18 11:14:15 CTS FIX Historical Data: Connected to Historical data server. | 2017-10-18 11:14:15 HD Request # 11 | Requesting historical Tick data for ES.20171200.CME_Eq from 2017-10-18 00:00:00 to 2017-10-18 00:00:00 (US Central Time). | 2017-10-18 11:14:15 HD Request # 11 | Receiving Intraday data for ES.20171200.CME_Eq starting at 2017-10-17 17:00:00 | 2017-10-18 11:14:15 HD Request # 11 | Timestamp of first Intraday data file record written: 2017-10-18 11:12:22 | 2017-10-18 11:14:15 HD Request # 11 | Total records received: 106205 | 2017-10-18 11:14:15 HD Request # 11 | Requesting historical Tick data for ES.20171200.CME_Eq from 2017-10-19 00:00:00 to 2017-10-19 00:00:00 (US Central Time). | 2017-10-18 11:14:15 HD Request # 11 | Total records received: 106205 | 2017-10-18 11:14:16 HD Request # 11 | Requesting historical Tick data for ES.20171200.CME_Eq from 2017-10-20 00:00:00 to 2017-10-20 00:00:00 (US Central Time). | 2017-10-18 11:14:16 HD Request # 11 | Received 106205 records from 2017-10-17 17:00:00 to 2017-10-18 11:14:16 (18.2 hours) and wrote 365 records for ES.20171200.CME_Eq | 2017-10-18 11:14:16 HD Request # 11 | Intraday download COMPLETE for ES.20171200.CME_Eq. Completion time: 0s. Unique request ID: 9 | 2017-10-18 11:14:16 Removed historical data download ID 9 | 2017-10-18 11:14:16 Real-time Intraday chart data file updates started for ES.20171200.CME_Eq | 2017-10-18 11:14:16 Intraday chart data file opened for ES.20171200.CME_Eq | 2017-10-18 11:14:16 HD Request # 12 | Downloading Intraday chart data for 6E.20171200.CME_Fo to the file 6E.20171200.CME_Fo.scid. Service: cts | 2017-10-18 11:14:16 HD Request # 12 | Download start date-time: 2017-10-18 11:12:16.000 | 2017-10-18 11:14:16 HD Request # 12 | Requesting historical Tick data for 6E.20171200.CME_Fo from 2017-10-18 00:00:00 to 2017-10-18 00:00:00 (US Central Time). | 2017-10-18 11:14:16 HD Request # 12 | Receiving Intraday data for 6E.20171200.CME_Fo starting at 2017-10-17 17:00:00 | 2017-10-18 11:14:16 HD Request # 12 | Timestamp of first Intraday data file record written: 2017-10-18 11:12:25 | 2017-10-18 11:14:16 HD Request # 12 | Total records received: 92168 | 2017-10-18 11:14:16 HD Request # 12 | Requesting historical Tick data for 6E.20171200.CME_Fo from 2017-10-19 00:00:00 to 2017-10-19 00:00:00 (US Central Time). | 2017-10-18 11:14:16 HD Request # 12 | Total records received: 92168 | 2017-10-18 11:14:17 HD Request # 12 | Requesting historical Tick data for 6E.20171200.CME_Fo from 2017-10-20 00:00:00 to 2017-10-20 00:00:00 (US Central Time). | 2017-10-18 11:14:17 HD Request # 12 | Received 92168 records from 2017-10-17 17:00:00 to 2017-10-18 11:14:03 (18.2 hours) and wrote 83 records for 6E.20171200.CME_Fo | 2017-10-18 11:14:17 HD Request # 12 | Intraday download COMPLETE for 6E.20171200.CME_Fo. Completion time: 0s. Unique request ID: 10 | 2017-10-18 11:14:17 Removed historical data download ID 10 | 2017-10-18 11:14:17 Real-time Intraday chart data file updates started for 6E.20171200.CME_Fo | 2017-10-18 11:14:17 Intraday chart data file opened for 6E.20171200.CME_Fo | 2017-10-18 11:14:17 Opened cached Intraday file: F:\SierraChart\Data\6E.20171200.CME_Fo.scid | 2017-10-18 11:14:21 Opened cached Intraday file: F:\SierraChart\Data\ES.20171200.CME_Eq.scid | 2017-10-18 11:14:31 CTS FIX Historical Data socket (78) | Socket gracefully closed by remote side. | 2017-10-18 11:15:17 CTS FIX Historical Data socket (78) | Received socket Close event | 2017-10-18 11:15:17 CTS FIX Historical Data socket (78) | Initiating close of socket by core. | 2017-10-18 11:15:17 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2017-10-18 11:15:17 CTS FIX Historical Data socket (78) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-18 11:15:17 CTS FIX Historical Data socket (78) | Closed. | 2017-10-18 11:15:17 CTS FIX Historical Data: Disconnected. | 2017-10-18 11:15:17 The above has been sent to support. | 2017-10-18 11:17:49 * HTTP connection to www.sierrachart.com:80 (80) | Creating socket. | 2017-10-18 11:17:49 HTTP connection to www.sierrachart.com:80 (80) | Connecting to IP: 204.15.192.108. | 2017-10-18 11:17:49 Sending of the message log was completed. Please read the response that was received. The response was saved to F:\SierraChart\Data\MessageLogAnalysis.htm | 2017-10-18 11:17:50 HTTP connection to www.sierrachart.com:80 (80) | Socket gracefully closed by remote side. | 2017-10-18 11:17:54 HTTP connection to www.sierrachart.com:80 (80) | Received socket Close event | 2017-10-18 11:17:54 HTTP connection to www.sierrachart.com:80 (80) | Initiating close of socket by core. | 2017-10-18 11:17:54 HTTP connection to www.sierrachart.com:80 (80) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-18 11:17:54 HTTP connection to www.sierrachart.com:80 (80) | Closed. | 2017-10-18 11:17:54 |
| [2017-10-18 17:50:01] |
Based upon what we see this appears to be a problem with your Internet connection. There is some connectivity problem between Sierra Chart and the CTS server. In one case the CTS server closed the connection: CTS FIX socket (21) | Socket gracefully closed by remote side. | 2017-10-18 11:12:37 We are seeing various types of connection problems. Not just one particular one. All kinds of different ones. CTS FIX socket (19) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-10-18 08:51:34 * Error getting address info for fix-chart.t4login.com. Windows error code 11001: No such host is known. | 2017-10-18 11:13:43 * CTS FIX socket (72) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-10-18 11:13:44 There are others as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-18 17:51:05
