Date/Time: Mon, 29 Apr 2024 05:52:04 +0000
delete data files
View Count: 1385
[2013-09-10 02:42:10] |
bullyboy - Posts: 11 |
I have many old data files, mostly ES YM NQ quarterly files dated 2009 - 10-11. I don't need them so I would like to delete them. Can I just open the data file folder,right click on file and delete ? My data file folder has over 3GB of files so I should free up a lot of space. Thank You
[2013-09-10 02:58:24] |
Yes, this is the proper procedure to follow.
