Date/Time: Sat, 27 Apr 2024 02:17:35 +0000
Replay rate: bars per minute?
View Count: 2340
[2013-04-04 02:14:02] |
mulesrule - Posts: 14 |
Can I do a replay at a fixed rate per minute? I'd like to have a comfortable rate that would be the same on all charts and would not vary by time of day.
[2013-04-04 22:05:57] |
Yes. Simply set the Replay Speed to what you need.
[2013-04-04 23:28:16] |
Thanks, but I meant on range and tick charts.
[2013-04-08 18:08:24] |
With the way Sierra Chart replay works, you will always have a fixed replay time per minute.
