Date/Time: Sat, 18 May 2024 13:22:57 +0000
Preset shareable Color Themes?
View Count: 3063
[2017-10-13 10:38:53] |
custodiet - Posts: 8 |
Hi Is there anywhere to access other color themes for the charts? without having to change each color myself? I basically would prefer a black background, but don't wanna find out later that something got hidden inadvertently. If some can share dark color preset that would be great too. Pls help. Thanks. |
[2017-10-13 12:16:43] |
Xfanman1 - Posts: 320 |
Here is my configuration file for the Global Settings if you find it useful. I've attached a copy of my main platform with these colors. The background is not "Black" but a dark charcoal, black is too hard on my eyes but of course you can change whatever you want.
Date Time Of Last Edit: 2017-10-13 12:23:08
Sierra3.cfg - Attached On 2017-10-13 12:15:58 UTC - Size: 376.95 KB - 534 views Dark Theme.PNG / V - Attached On 2017-10-13 12:23:01 UTC - Size: 251.12 KB - 1641 views |
[2017-10-13 13:00:05] |
Thank you :D Very kind of you. |
[2017-10-13 16:41:02] |
Xfanman, I noticed your times for RTY futures are off by +1 hour on the charts. They seem to be reflecting EST? , when in fact it should be CST. Your thoughts?
[2017-10-13 17:06:43] |
In regards to the Sierra3.CFG file provided. You need to put that into the main Sierra Chart folder and do that only when Sierra Chart is not running. You can use any time zone that you want. Refer to: Time Zone Setting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-13 19:37:25] |
I'm on Eastern Standard Time and since the Index Futures open aligns with the Equity Markets I base all my times off of that time zone. I have background color changes on my charts setup to give me a heads up when each market is about to Open or Close "just in case". Thanks |
[2017-10-16 09:17:56] |
PS where is the best place to reset the times to original exchange settings if u have a minute :) Basically want to ensure i only inherit your color settings :D Date Time Of Last Edit: 2017-10-16 09:18:28
[2017-10-16 10:08:01] |
To the best of my knowledge, you set the Time Zone under Global Settings/Data/Trade Service Settings/Time Zone and/or you can set each charts Session time under Chart/Chart Settings/Main Settings/Session Times.
[2019-12-24 01:44:46] |
User426557 - Posts: 3 |
Does anyone have a light color theme they can share? Thanks!
