Date/Time: Mon, 29 Apr 2024 15:00:34 +0000
TPO Poor Low/Poor high Projection line
View Count: 1049
[2017-10-12 07:58:52] |
Dom7364 - Posts: 257 |
Is there a way to project a line forward, in the same way that it can be done for Single prints, for poor lows/poir highs (one print/letter only at the top or bottom of a completed TPO daily profile)?
[2017-10-12 17:03:41] |
No, this is not supported at this time.
[2017-11-30 21:59:19] |
User40526 - Posts: 166 |
Just being able to project any TPO chart daily highs and lows until intersected would be a great addition to SC. Thanks |
