Date/Time: Tue, 21 May 2024 14:34:20 +0000
Log in
View Count: 1245
[2017-10-12 07:02:28] |
User391949 - Posts: 14 |
Hello, I updated my sierra chart about 20 minutes ago and then it stopped working in terms of me not able to login with my details issued by AMP futures. I use sierra chart platform with CQG data feed. Please let me know how to fix this. |
[2017-10-12 08:36:44] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-12 09:10:25] |
The sierra message log containing the relevant information is at work. I am now at home and so have no access to it at the moment. However, I also have sierra chart at home and I just checked, it was working fine at home, since I did not update it. I remember from the message log at work that part of the message says 'UserName does not exist. Contact Customer Support for assistance.' I also tried restarting my PC at work in safe mode with networking so as to make sure that it wasn't a firewall problem, and that did not work either.
[2017-10-12 09:47:42] |
That particular message is from the CQG system. One thing to check is Global Settings >> Data/Trade Service Settings >> Service Setting >> Server. It should be Live. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
