Date/Time: Sat, 18 May 2024 08:23:54 +0000
User Question
View Count: 743
[2017-10-11 17:00:10] |
Sierra Chart - Max - Posts: 5618 |
Is it possible to run both automated trading and manual regular trading on the same account? Will that cause any problem?
Sierra Chart Support |
[2017-10-11 17:39:15] |
Yes, this can be done. This is definitely no problem.
