Date/Time: Sat, 18 May 2024 05:24:56 +0000
data flow
View Count: 575
[2017-10-11 16:16:12] |
david a rudes - Posts: 4 |
I'm using sc data flow but it's frozen. I do have a green bar on the upper left of my chart. Why isn't the count down timer showing movement?? I'm trying to do simulated trading but it's not working. |
[2017-10-11 16:21:58] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
