Date/Time: Sat, 18 May 2024 06:48:50 +0000
Data
View Count: 755
[2017-10-11 15:04:39] |
User82486 - Posts: 43 |
I am having problems with data flows in both direction when trading STOKES. My second instance of Sierra with AMP works fine. The problem lies with Ameritrade. When the data flows it is usually in spurts of up to ten seconds before the count down timer indicates the passage of time. Having used Sierra for years I am reluctant to switch to another charting system provided by a broker. Sierra does not seem to have connections to stock brokers except for Interactive and TD Ameritrade. I have had the same problems when I had an Interactive brokers account Ir seems to me that your strength lies with Futures Brokers but no depth in Stock brokers. I really would hate to give up my Sierra charts. Do you have any suggestions? Fred Epstein |
[2017-10-11 17:29:00] |
Consider using the Sierra Chart Exchange Data Feed for US equities data: Sierra Chart Exchange Data Feed The cost is 35 USD per month +10.50 USD per month for the exchange fee. This data feed is fully integrated when using either Interactive Brokers or TD Ameritrade, so that you can continue to use those for trading. And for stock trading we recommend using Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-11 17:30:52
