Date/Time: Thu, 23 May 2024 16:52:50 +0000
Control bar not working
View Count: 635
[2017-10-11 10:54:21] |
User821872 - Posts: 7 |
The main control bar has some issues since Windows 10 made some updates and I can't use the platform. The control bar is still there but the first button has a ginormous width, occupying all the monitor space, thus not showing the name on the button and other buttons. I attach a screenshot. Thank you. |
Control bar.PNG / V - Attached On 2017-10-11 10:53:03 UTC - Size: 5.88 KB - 216 views |
[2017-10-11 16:24:21] |
Refer to this section about this: Control Bar: Control Bar Buttons Too Large Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-11 16:26:21
