Date/Time: Sun, 28 Apr 2024 03:43:03 +0000
cant modify chart settings
View Count: 1749
[2013-04-04 02:48:23] |
What you need to do is open a new Intraday chart through File >> Find Symbol and then add the TPO Profile Chart study. With the way the TPO study works you will have the difficulty you describe without first starting with an Intraday chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
