Date/Time: Sat, 18 May 2024 15:56:20 +0000
Error on building custom study following version update
View Count: 981
[2017-10-08 23:11:32] |
Blue Brazilian - Posts: 42 |
I completed the update to the latest version today and now when I try to build a custom study, I get the following message: C:\windows\System32\cmd.exe /C "C:\Sierra_AMP\ACS_Source\VisualCCompile.Bat"
C:\Sierra_AMP\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" 'cl' is not recognized as an internal or external command, operable program or batch file. I've tried re-compiling studies that I know have previously compiled successfully but get the same error. I tried rolling back to the previous version of Sierra but that made no difference. It seems to be a problem in the compiler itself. Do I need to re-install the compiler? |
[2017-10-08 23:34:06] |
Use the "Remote Build" button instead.
[2017-10-09 00:37:25] |
OK that works. Thanks- Is this a temporary measure or should I always Remote Build? I understood that Remote Build was only needed if there was a problem with the Visual C++ compiler. Would a reinstall of the compiler fix it? |
[2017-10-09 00:53:59] |
Always use Remote Build. We have no idea whether reinstalling Microsoft Visual C++ is going to help. We do not provide support for that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
