Date/Time: Sat, 18 May 2024 16:54:21 +0000
replay not working
View Count: 1384
[2017-10-08 01:38:02] |
User98657 - Posts: 304 |
I've transferred my SC to a new machine and everything seems to be fine. After the transfer everything seemed to be working correctly. Per support board advice i updated to the current version and compressed my data file (it had reached 99GB). I set the days to 240 and the compression to 4 seconds. That seemed to work well. I've explained all that in case it is impacting my replay. for some reason when i click on Replay Chart (Control Panel) nothing happens. i don't see the replay panel eappear and i do not get chart replay. Looking for reasons as to why this might be happening. |
[2017-10-08 01:54:52] |
This is explained here: Replaying Charts: Chart Replay Window Not Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
