Date/Time: Sat, 18 May 2024 11:01:57 +0000
Moving Average Text
View Count: 887
[2017-10-07 16:55:10] |
User417302 - Posts: 66 |
When using a black background for charts how do I change the price text to white from black with darker colors? Basically want to see black text for a white ma and white text for a dark red ma.
[2017-10-08 01:21:55] |
This is not totally clear for us but the text associated with the Study Subgraph is going to have the same color as the Study Subgraph. Would be best to post an image of the chart so we can understand this better. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-08 01:22:39
[2017-10-08 19:41:36] |
Sure I have attached a picture of what I am looking for (different software). You'll notice that depending on how dark the color is then the text changes to either white or black so that it can be seen easier on the side. Basically I am looking for the m/a values on the right to have the ability to have the text color changed.
Screen 3 - Steering Wheel.PNG / V - Attached On 2017-10-08 19:37:56 UTC - Size: 222.43 KB - 266 views Attachment Deleted. |
[2017-10-09 06:53:44] |
This is not supported.
