Date/Time: Sat, 18 May 2024 18:04:55 +0000
Single vs Multiple chart performance
View Count: 771
[2017-10-06 21:19:32] |
samual sprat - Posts: 343 |
Hi, just wondering what the best way to lay out my charts and studies is within a chartbook. I have assumed that using a single chart referencing multiple charts via Study Price Overlays and then displaying using Bar Colour on the main chart is the best approach for me atm. But it is the most efficient method? Seems that I could reduce the number of Studies I need to use if I put all the studies hidden on the main chart and then just use Bar colour, without the need to Study Overlays. Is there much of an impact in terms of performance from running extra charts and study overlays? Just picked up Sierra last week so forgive me if this is common knowledge, I tried to search on it Thanks S |
[2017-10-06 21:52:58] |
From our perspective this is hard to understand. You will just have to evaluate what is best for you. There is not a way that we can answer this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
