Date/Time: Mon, 20 May 2024 02:13:51 +0000
Interactive Brokers problem with stocks.
View Count: 678
[2017-10-05 17:57:06] |
User115866 - Posts: 1 |
Hello, I have an account with Interactive Brokers and I cannot see and select the stocks in "Find Symbol". I have followed all the instructions on your site to adjust the Interactive Brokers and Sierra Chart software, but it still does not work. Could you please check why the stock section is empty please! Thank you for your help ! Regards, Peter |
Capture-Stocks.JPG / V - Attached On 2017-10-05 17:54:52 UTC - Size: 97.13 KB - 253 views |
[2017-10-05 18:23:37] |
Stock symbols must be manually entered. Refer to: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html The documentation does explain this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
