Date/Time: Mon, 20 May 2024 02:48:51 +0000
Very slow AutoTrade Bar Based BackTest
View Count: 1753
[2017-10-05 16:37:33] |
jenda3 - Posts: 21 |
Hello I have a problem with the new version of sierra chart 1621 (clean installation). When running AutoTrad System Bar Based BackTest, it is very very slow. I compared it with an older version of sierra chart 1538 (clean installation), and in 1538 BackTest is much faster than version 1621 Here's a video that compares both versions: https://youtu.be/1SVQvzJqS2Y Where is the problem? Thank you for answer. |
[2017-10-05 17:05:53] |
Provide us the particular chart you are back testing. Here are instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-05 17:33:38] |
Here is. This is chart from sierra 1621
Date Time Of Last Edit: 2017-10-05 17:46:44
Private File |
[2017-10-06 06:28:22] |
The first thing we want you to do is to check the Global Settings >> General Settings >> Chart Update Interval and make sure they are the same between versions. There is also going to be more processing in the newer version, due to the maintaining of the symbol data during the replay. We will look into this and possibly remove that extra processing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-06 14:29:11] |
Thanks. This is it.
[2017-10-06 16:43:42] |
OK we are still going to look into this and more and see what further we can do to make sure there is maximum performance.
