Date/Time: Sun, 19 May 2024 22:32:20 +0000
Alert referencing other than bar
View Count: 745
[2017-10-04 18:30:00] |
Devil_On_WallStreet - Posts: 67 |
I think the best way to ask this is by giving an example... Lets use the zigzag tool for this example... Instead of comparing to [-x] bars ago.. I'm wondering if there is a way to make it look back at [-high/low] of the zig zag... or any other study that outputs in a similar way? An easy example would be.. if the current zig zag high is lower than the last... independent of how many bars are there? Or doing it with fractals etc... referencing the previous regardless of how many bars are there? Hope that makes sense
[2017-10-04 18:53:13] |
This is not supported. You would have to custom program this using ACSIL: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-04 21:40:22] |
Sawtooth - Posts: 4001 |
This can also be done with a spreadsheet study.
