Date/Time: Sat, 27 Apr 2024 10:11:07 +0000
how to put number on indicator
View Count: 1665
[2017-10-04 07:27:32] |
Donz - Posts: 17 |
hello, how to pun an number on indicator let say i want to see only value that above 50 |
Screenshot_3.png / V - Attached On 2017-10-04 07:27:20 UTC - Size: 326.44 KB - 626 views |
[2017-10-04 18:45:25] |
This is not clear for us. The numbers we see on that chart, what is causing those to be displayed? Are you using the Value On High study Subgraph Draw Style or something like that? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-04 18:45:45
[2017-10-04 22:49:58] |
Donz - Posts: 17 |
Yes...i think it is Value on High study subgraph can i filter the number on specific |
[2017-10-05 04:13:34] |
No you cannot do filtering with that study Subgraph without writing your own custom code. Refer to: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
