Date/Time: Mon, 20 May 2024 06:33:37 +0000
round to nearest tick size for extend bar values until future intersection possible?
View Count: 1067
[2017-10-03 14:30:24] |
User541842 - Posts: 34 |
hi there, wanted to ask if you can add this feature. thanks in advance |
[2017-10-03 18:06:31] |
What is the purpose of this? The values are already rounded.
[2017-10-04 06:31:14] |
not if you take the hl avarage
[2017-10-04 17:29:01] |
OK, then use this study for this: Round Study Subgraph to Tick Size Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-05 17:43:19] |
this does not work
[2017-10-05 18:18:03] |
Actually, that does make sense since that study uses extension lines and not normal study Subgraphs.
