Date/Time: Wed, 08 May 2024 11:19:57 +0000
[User Discussion] - Bid/Ask volume cluster analysis ... & ... code for reading scid files.
View Count: 3133
[2013-09-08 11:47:02] |
marcovth - Posts: 61 |
Hello ... I want to attempt to perform some of my own Bid/Ask volume cluster analysis (search with orderflowanalytics for some video's on the topic). I have cluster analysis of biological data in the past, and I like to figure out if orderflowanalytics.com is using the same techniques with bid/ask volume. I don't think ACSIL is giving direct access to the number bar arrays (data), so I would have to read scid files to generate my own number bar arrays in the background. But first: DarthSidious ... is this your only version of your scid reading script, or could you share a better version? http://www.sierrachart.com/supportboard/showthread.php?t=36261 Thanks in advance. |
[2013-09-08 14:10:01] |
ganz - Posts: 1048 |
marcovth I don't think ACSIL is giving direct access to the number bar arrays (data)
imho ACSIL provides it use http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scVolumeAtPriceForBars http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scPullbackVolumeAtPrice i've used it for some kind of ofa: http://www.sierrachart.com/supportboard/showthread.php?t=37616 Date Time Of Last Edit: 2013-09-08 14:12:43
[2013-09-08 18:14:15] |
Thanks a lot Ganz! This will provide a lot of data I can play with next week. :)
[2013-09-08 20:27:54] |
This is what you need to use: http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scVolumeAtPriceForBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-10 09:20:20] |
Cavalry3162 - Posts: 523 |
marcovth, may i ask if you came up with an indicator? if so, do you mind sharing it? thanks, Andreas |
