Date/Time: Fri, 03 May 2024 13:22:17 +0000
SG Drawtype request
View Count: 1270
[2017-09-30 19:55:32] |
@sstfrederik - Posts: 403 |
Hi, I am working for a client and would like to inquire about the possibility of adding a new SG drawtype set. I am currently using: DRAWSTYLE_LEFT_OFFSET_BOX_BOTTOM but it is not ideal. The requested drawtype is a transparent offset rectangle or offset transparent filled box. Something like: DRAWSTYLE_TRANSPARENT_FILL_RECTANGLE_LEFT_OFFSET_TOP DRAWSTYLE_TRANSPARENT_FILL_RECTANGLE_LEFT_OFFSET_BOTTOM DRAWSTYLE_TRANSPARENT_FILL_RECTANGLE_RIGHT_OFFSET_TOP DRAWSTYLE_TRANSPARENT_FILL_RECTANGLE_RIGHT_OFFSET_BOTTOM Thanks for the consideration. Frederik |
[2017-09-30 23:12:22] |
It would be helpful if you could provide a graphic showing more precisely what you need. Otherwise, this is not clear enough for us to work on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-01 06:31:01] |
I attached a picture with the idea. If transparency can be an option per SG that would be great as well. Kind regards, Frederik |
Attachment Deleted. IMG_1823.PNG / V - Attached On 2017-10-01 06:29:10 UTC - Size: 78.47 KB - 416 views |
[2017-10-05 09:19:10] |
We are working on new Draw Styles to accomplish this.
[2019-11-20 01:40:01] |
Sierra_Chart Engineering - Posts: 14194 |
We are going through old development requests. Do you need anything further here?
[2019-11-20 02:54:27] |
This would be great. I have nothing further at the moment. Thanks.
